POV-Ray : Newsgroups : povray.bugreports : Not a Bug but Like a Bug: rendering a part and errors Server Time
16 May 2026 14:54:30 EDT (-0400)
  Not a Bug but Like a Bug: rendering a part and errors (Message 1 to 3 of 3)
Subject: Not a Bug but Like a Bug: rendering a part and errors
Date: 18 Jan 2016 12:20:42
Message: <569d1eea$1@news.povray.org>
imagine you have rendered a scene completely. Then you make so me
changes, and want - in order to avoid lots of render time - to render
just an area (a part) of the scene by selecting that area inside the
render window.
If you didn't make any errors in scene writing, fine. You get your area
render.
But if you made any error, POV-Ray of course quits with an error
message, but also unfortunately your previously rendered complete (or
partial) scene disappears, you cannot select any area again inside the
now empty render window, and are forced to render the entire scene again
just to have selectable areas again (if you didn't write down the area
coordinates with paper and pen). That costs a lot of time. my last full
render took 6 days!!!
My advise: allow the render window to keep the last successful render.
Or make it possible to load last-rendered images (via dropdown) into it.
Subject: Re: Not a Bug but Like a Bug: rendering a part and errors
Date: 18 Jan 2016 17:45:24
Message: <569d6b04$1@news.povray.org>
Am 18.01.2016 um 18:20 schrieb Sven Littkowski:
> Hi,
> render window.
> render.
My advise: Whenever you want to render a subsection of an image "for
realz" rather than just for a quick render, make it a habit of using the
shift key while selecting the area; this will copy the corresponding
parameters into the command-line field, from where you can back them up
to any other medium you like.
The world around you does provide you with some assistance for not
shooting yourself in the foot. Be wise and actively use it, rather than
putting the blame on others when you later do find yourself with a
perforated limb.
That said, if you ever /do/ forget to press shift, selecting the message
pane and clicking "render" will re-run the last render, including
"quiet" subsection settings.
Date: 18 Jan 2016 19:15:39
Message: <569d802b$1@news.povray.org>
Nice. These are two useful advises. And yes, I am going to use them.
This is going to help me a lot.   :-)
But besides, would that not be a good idea for the next version, to
avoid that the render window shows nothing, in the situation I mentioned?
