POV-Ray : Newsgroups : povray.bugreports : Grayscale_Output=yes doesn't work Server Time
18 Apr 2024 14:02:49 EDT (-0400)
  Grayscale_Output=yes doesn't work (Message 1 to 10 of 11)
Subject: Grayscale_Output=yes doesn't work
Date: 13 Mar 2015 17:34:26
Message: <550357e2@news.povray.org>
I've got
  Micrsoft Windows XP
  Home Edition
  Version 2002
  Service Pack 2
  Intel(R) Pentium(R) Dual CPU
   E2160 @ 1.80GHz
  1.79Ghz, 0.99 GB of RAM
Pov version 3.7.0Rc7.msvc10-sse2.win32
I've tried putting it in the ini like the docs say.
I've put in the the comand line option windows has.
I even change the version to 3.6 and put 'hf_gray_16 in global_settings.
I haven't try to output to a file (there's no point if you can't display
it).
Any Ideals?
Subject: Re: Grayscale_Output=yes doesn't work
Date: 13 Mar 2015 19:57:44
Message: <55037978$1@news.povray.org>
Le 13/03/2015 23:33, Leroy a écrit :
> I've got
>  Micrsoft Windows XP
>  Home Edition
>  Version 2002
>  Service Pack 2
>   E2160 @ 1.80GHz
> it).
> Any Ideals?
As stated in the doc: hg_gray_16 is deprecated, and no more effective
with 3.7 (even in compatibility mode).
http://wiki.povray.org/content/Reference:Global_Settings
Grayscale_Output need a png or ppm output format.
I would concede that despite the documentation, the preview is not
greyscale (at least on my linux). But the output image is greyscale, and
16 bits.
gray.ini
Grayscale_output=true
gray.pov
#version 3.7
global_settings { assumed_gamma 1.0 }
camera { location <0,0,-100>
up y
direction z
right image_width/image_height*x
sphere { 0, 30 texture { pigment { color red 1 } finish { emission 0.5 } } }
light_source { <40,-30,-20>*20, 1 }
Command-line
povray gray.ini -Igray.pov
Date: 14 Mar 2015 12:34:56
Message: <55046330@news.povray.org>
 >and 16 bits.
So is this a document thing or a bug?
My bet is a bug.
Date: 15 Mar 2015 01:09:52
Message: <55051420$1@news.povray.org>
Am 14.03.2015 um 18:34 schrieb Leroy:
>  >and 16 bits.
> My bet is a bug.
Nope; it is the documentation that is in error.
Making the preview exactly reflect the output image in every respect
would be excessively difficult. (As an extreme example, reproducing jpeg
artifacts according to the quality settings chosen would require to
actually generate the jpeg image and then convert it back. Obviously
that can only happen once the image is completely rendered. The same
goes for some dithering options at low bit depths.) For consistency, it
is therefore the current policy to always preview the render at maximum
quality regardless of the output file format and quality parameters.
In that context, the question whether the output image contains any
chromaticity information at all is currently considered a matter of
output file format and quality.
Date: 15 Mar 2015 09:09:07
Message: <55058473@news.povray.org>
>>  >and 16 bits.
>> My bet is a bug.
http://wiki.povray.org/content/Reference:Global_Settings#HF_Gray_16
of course you all will let me know if i didn't get it right ;-)
Date: 16 Mar 2015 13:02:05
Message: <55070c8d$1@news.povray.org>
>> My bet is a bug.
I lost my bet! Never been good at gambling anyway.
For consistency, it
So does that means the display option +Dxy have deprecated functions too?
Date: 16 Mar 2015 15:43:37
Message: <55073269$1@news.povray.org>
Am 16.03.2015 um 19:01 schrieb Leroy:
>> jpeg artifacts according to the quality settings chosen would require
>> to actually generate the jpeg image and then convert it back.
>> Obviously that can only happen once the image is completely rendered.
>> The same goes for some dithering options at low bit depths.)
>> For consistency, it
>> maximum quality regardless of the output file format and quality
>> parameters.
Um... actually, no: In the Windows version they don't have any functions
at all :P (Don't know about Unix off the top of my hat, but there it
either does something non-deprecated, or nothing at all either.)
Those options certainly date back to the DOS versions (or even earlier).
Date: 16 Mar 2015 19:42:34
Message: <55076a6a@news.povray.org>
Another thing the documentation needs updating.:) I had to check, the -D
display option works OK. Thats all I really need anyway. I like for long
animation runs.
Date: 17 Mar 2015 07:02:48
Message: <550809d8$1@news.povray.org>
>>> For consistency, it
>>> parameters.
as far as i can tell the video_mode and palette options have no effect
and produce no warning etc, so they've been removed:
http://wiki.povray.org/content/Reference:Display_Output_Options#Display_Hardware_Settings
Date: 17 Mar 2015 13:03:37
Message: <55085e69$1@news.povray.org>
>>>> For consistency, it
>>>> parameters.
>>> too?
Correct. They were options for the old X11 API/toolkit, something that
is taken care of by the SDL API (Not that Scene Description Language)
itself now.
