POV-Ray : Newsgroups : povray.bugreports : Strong pigment gradients, SSLT and AA Server Time
6 Sep 2025 19:49:49 EDT (-0400)
  Strong pigment gradients, SSLT and AA (Message 1 to 6 of 6)
Subject: Strong pigment gradients, SSLT and AA
Date: 29 Nov 2013 06:42:15
Message: <52987d97$1@news.povray.org>
Hello,
POV-Ray 3.7.0 64bit, Windows 8.1
I noticed that if a material has SSLT enabled and its pigment has a
strong gradient, such as a dark line or black area the anti-aliasing
breaks at the edge of the two colors. This is more noticeable if the
image is high resolution.
See images below. The scene is a mesh sphere with an image map pigment.
It was rendered with radiosity, anti-aliasing (+am2 +a0.01 +r3). The
SSLT mm per units is 24.5.
no SSLT:
http://imgur.com/t2Oqqhm
Notice the anti-aliased transition between the colors on the sphere.
With SSLT (marble):
http://imgur.com/MoGWfDq
The edges between the colors are strongly aliased. Almost looks as if AA
is switched off but the edge of the sphere shows that AA is active.
This happens with any AA and SSLT setting I use. Also image
interpolation does not eliminate this effect. Only way to avoid it is
not using SSLT.
You can download the scene, with SSLT enabled, from this Google drive link:
https://drive.google.com/file/d/0B0MYeki9vLYYRGtVRnZOZ0NMMG8/edit?usp=sharing
file->download to get the entire archive.
FlyerX
Subject: Re: Strong pigment gradients, SSLT and AA
Date: 29 Nov 2013 10:55:01
Message: <web.5298b897928854e17a3e03fe0@news.povray.org>
FlyerX <fly### [at] yahoocom> wrote:
> Hello,
> FlyerX
==== [Parsing...] ==========================================================
povray: backend/render/trace.cpp:3535: void
pov::Trace::ComputeDiffuseContribution(const pov::Intersection&,
const pov::Vector3d&, const pov::Vector3d&, const pov::Vector3d&,
const pov::Vector3d&, double&, double, double, double): Assertion `(sd >= 0.0)
&& (sd <= double(1.79769313486231570815e+308L))' failed.
Emergency stop
POV-Ray 3.7.0 64bit, Linux Mageia 3
Date: 29 Nov 2013 11:08:13
Message: <5298bbed@news.povray.org>
Am 29.11.2013 12:42, schrieb FlyerX:
> With SSLT (marble):
Try to avoid zero color components; for instance, you could use an
"average" pigment with a small bit of white mixed in. Something like
0.001 shoud already be sufficient.
What happens is that currently the SSLT code cannot yet cope with zero
color components, belches out a "Not a Number" (NaN) value for that
particular color channel, and the AA step is unable to handle that,
computing the average of NaN and any other valid number as NaN. The
image encoding algorithm then happens to encode the NaN as 0.
Date: 29 Nov 2013 16:12:26
Message: <5299033a$1@news.povray.org>
>> With SSLT (marble):
Clipka,
Thank you very much for the tip. No wonder the red area in the render
was completely noisy.
I added the following to the material:
#declare pave=pigment{average pigment_map{
     [1 p_map1]
     [1 color rgb 0.001]
and called pave in the material{} instead of p_map1 and the AA is back.
There is a very small render time penalty (6%) but at least it works
better now.
I will put this workaround in PoseRay tonight.
later,
FlyerX
Date: 29 Nov 2013 17:04:56
Message: <52990f88$1@news.povray.org>
Am 29.11.2013 22:12, schrieb FlyerX:
>>> With SSLT (marble):
> Clipka,
>      [1 p_map1]
>      [1 color rgb 0.001]
I would instead suggest
      [1 p_map1]
      [0.001 color rgb 1]
as this leaves the resulting color almost unchanged, whereas your
solution gives any non-black color a significant blackshift.
Date: 29 Nov 2013 18:10:10
Message: <52991ed2$1@news.povray.org>
>>>> With SSLT (marble):
>>>> if AA
>> Clipka,
>>      [1 p_map1]
>>      [1 color rgb 0.001]
>       [1 p_map1]
>       [0.001 color rgb 1]
That makes sense. I noticed the darkening but I though I would have to
live with that. Now I just see that I was averaging black with the
original. Using the weight makes the render look as expected.
Thanks again,
FlyerX
