POV-Ray : Newsgroups : povray.bugreports : Bug in rendering of Bézier_patches Server Time
13 Jul 2025 07:28:17 EDT (-0400)
  Bug in rendering of Bézier_patches (Message 1 to 10 of 11)
Subject: Bug in rendering of Bézier_patches
Date: 21 Mar 2013 16:41:21
Message: <514b7071$1@news.povray.org>
Hi!
patches in which four points (along one edge) are all the same point.
The rendering can be seen here:
	http://i.imgur.com/eq2UIXR.png
As you can see, there is a visible unwanted artifact in the corner of
each patch. The two patches shown are essentially the same, except with
Expected rendering is a smooth surface without the artifact.
Below is the code used to render the above example.
Thanks
Timwi
#version 3.7;
global_settings { assumed_gamma 1.0 }
     location <45, 31, -10>
     look_at <40, 21, 200>
light_source {
     <660, 300, -525>
     color rgb 1
// Example 1: First point in each row is the same point
bicubic_patch {
     type 1 flatness 0.001
     u_steps 4 v_steps 4
     <32.2168, -23.78125, 0>, <34.4968, -23.78125, 0>, <35.2168,
-23.78125, -0.72>, <35.2168, -23.78125, -3>,
     <32.2168, -23.78125, 0>, <34.4968, -22.10256, 0>, <35.2168,
-21.57244, -0.72>, <35.2168, -21.57244, -3>,
     <32.2168, -23.78125, 0>, <33.9709, -21.55577, 0>, <34.52483,
-20.85299, -0.72>, <34.52483, -20.85299, -3>,
     <32.2168, -23.78125, 0>, <32.30556, -21.50298, 0>, <32.33359,
-20.78352, -0.72>, <32.33359, -20.78352, -3>
     rotate 180*x
     scale 1.4
     translate <-5, 0, 0>
     pigment { color <1, 0, 0> }
// Example 2: First row is all the same point
bicubic_patch {
     u_steps 4 v_steps 4
     <32.2168, -23.78125, 0>, <32.2168, -23.78125, 0>, <32.2168,
     <34.4968, -23.78125, 0>, <34.4968, -22.10256, 0>, <33.9709,
-21.55577, 0>, <32.30556, -21.50298, 0>,
     <35.2168, -23.78125, -0.72>, <35.2168, -21.57244, -0.72>,
<34.52483, -20.85299, -0.72>, <32.33359, -20.78352, -0.72>,
     <35.2168, -23.78125, -3>, <35.2168, -21.57244, -3>, <34.52483,
-20.85299, -3>, <32.33359, -20.78352, -3>
     rotate 180*x
     scale 1.4
     pigment { color <1, 1, 0> }
Subject: Re: Bug in rendering of Bézier_patches
Date: 23 Mar 2013 19:28:58
Message: <514e3aba@news.povray.org>
Am 21.03.2013 21:41, schrieb Timwi:
I'm not sure whether this actually qualifies as a bug, or just a
limitation. After all, that one point does constitute a singularity.
At any rate, this issue has been around for ages now - I recall having
stumbled across this problem when toying around with POV-Ray's bezier
patches back in the mid-90's.
Could you please file an issue report at http://bugs.povray.org?
Date: 24 Mar 2013 09:10:03
Message: <514efb2b$1@news.povray.org>
not change that fact, and most users will expect it to render properly.
fix it.
Timwi
Date: 24 Mar 2013 10:37:36
Message: <514f0fb0@news.povray.org>
> fix it.
> Timwi
The "Edit this task" button on the lower left hand side of the "Details"
area?
Date: 24 Mar 2013 12:16:31
Message: <514f26df$1@news.povray.org>
>> fix it.
> area?
There is none. http://screencast.com/t/YgGMFEcSWtn
I think someone should fix that.
Timwi
Date: 24 Mar 2013 12:26:43
Message: <514f2943$1@news.povray.org>
>>> fix it.
>> area?
> Timwi
I believe you have to be logged in to see that ... I hopped over there
and didn't log-in. Indeed it's missing in that case.
Date: 24 Mar 2013 13:44:11
Message: <514f3b6b$1@news.povray.org>
>>>> fix it.
>>> area?
I would bet that you have some sort of elevated privileges that allow
you to edit /any/ bug. Whoever is adminning this simply forgot to allow
bug submitters to edit /their own/ bugs.
Timwi
Date: 24 Mar 2013 15:34:10
Message: <514f5532$1@news.povray.org>
>>>>> fix it.
>>>> "Details"
>>>> area?
> Timwi
I'm not saying you're wrong ... but not allowing a user to edit their
own bug just doesn't make sense, and I believe the configure has been
working just fine in the past. I'm fairly sure that would have been a
problem long before now if it weren't
Subject: Re: Bug in rendering of Bézier patches
Date: 25 Mar 2013 03:55:34
Message: <515002f6$1@news.povray.org>
There is a preview link before committing. If you do not use it to see
that the formatting is wrong (it happened to me, where some code was
interpreted as flyspray syntax for note...), just blame yourself and
correct with an additional comment.
Editing text is dangerous for efficiency: one would look at the bug on
the 1st January with one description, and by the 15th March the
description would have been changed to something different. You do not
build a house on moving sand.
Just because nobody complains does not mean all parachutes are perfect.
Date: 25 Mar 2013 09:05:10
Message: <51504b86@news.povray.org>
Am 24.03.2013 14:10, schrieb Timwi:
A bug is something that is supposed to work but doesn't.
A limitation is something that was never supposed to work in the first
place.
The Bezier patch is intended for square patches, and wasn't designed
with triangular ones in mind. Therefore, if it doesn't work with
triangular patches, it would be fair to call it a limitation rather than
a bug.
As I said, I myself am not sure how I'd categorize it. My favored
approach to this issue would be to provide some kind of dedicated
triangular bezier patch for such use cases, but so far I haven't managed
to come up with consistent math for such an animal.
