POV-Ray : Newsgroups : povray.bugreports : polygon with overlap Server Time
7 Sep 2025 18:27:40 EDT (-0400)
  polygon with overlap (Message 1 to 2 of 2)
Subject: polygon with overlap
Date: 4 Jan 2011 15:22:00
Message: <4d238168$1@news.povray.org>
Greetings,
Can someone check if I made any error on the following script:
It should render [step] nested polygons of [num] sides.
But the rendered picture is bogus for me (both 3.6 & 3.7).
I searched the bugs site, but found no match for polygon.
#default { texture { pigment { rgb 1 }finish { ambient 1.0} } }
camera { orthographic
	up 3.5*y
  right 3.5*x*image_width/image_height
  location  <0,0,-4>
  look_at   <0,0,0>
#declare num=5;
#declare step=5;
#macro aa(xx,yy,a)
polygon { (num+1)*step,
#local j=0.70;
#while(j>0.01)
#local i=0;
#while(i<num+1)
  j*< cos(i*2*pi/num),sin(i*2*pi/num),0>
#local i=i+1;
#local j=j-0.7/step;
translate <xx-0.0,yy,0>
aa(0,0,0)
Subject: Re: polygon with overlap
Date: 4 Jan 2011 15:36:26
Message: <4d2384ca$1@news.povray.org>
Am 04.01.2011 21:21, schrieb Le_Forgeron:
> Greetings,
> But the rendered picture is bogus for me (both 3.6&  3.7).
Apparently the polygon code requires start and end points to /exactly/
match in order to recognize the end of a "sub-polygon"; you can work
around this with the following change:
> 	up 3.5*y
>    location<0,0,-4>
>    look_at<0,0,0>
> #declare num=5;
> #declare step=5;
> #macro aa(xx,yy,a)
> #local j=0.70;
> #while(j>0.01)
> #local i=0;
> #while(i<num+1)
replace this with
      j*<  cos(mod(i,num)*2*pi/num),sin(mod(i,num)*2*pi/num),0>
> #local i=i+1;
> #end
> #end
> translate<xx-0.0,yy,0>
> #end
> aa(0,0,0)
I'd consider it a bug nonetheless.
