POV-Ray : Newsgroups : povray.bugreports : Error messages not helpful when using macros Server Time
15 Dec 2025 22:18:16 EST (-0500)
  Error messages not helpful when using macros (Message 1 to 1 of 1)
Subject: Error messages not helpful when using macros
Date: 19 Jun 2010 18:14:15
Message: <4c1d4137$1@news.povray.org>
Normally if you encounter an error the message pane describes the last
few lines of code, and the editor automatically takes you to the
offending line of code.
If you use a lot of macros however it takes you to the macro definition
instead of the place where the macro was called from. The message window
also only shows the last few lines from the file containing the macro if
the macro is stored somewhere else from your main scene.
This is not very helpful. I'd rather also see some sort of stack trace
where you can view the execution hierarchy.
http://isometricland.com
