POV-Ray : Newsgroups : povray.bugreports : Rights on WinVista 64amd incorrect - crash on save Server Time
15 Dec 2025 22:17:04 EST (-0500)
  Rights on WinVista 64amd incorrect - crash on save (Message 1 to 2 of 2)
Subject: Rights on WinVista 64amd incorrect - crash on save
Date: 19 Nov 2008 05:30:34
Message: <4923eaca@news.povray.org>
Hello
::TECH-INFO::
I use Win Vista 64amd SP1 active autoupdate on an Athlon 64 X2 4200+
DualCore/4Gb/NVidia 8500 GT.
PovRay is V3.6.1.mscv8.win64.
::ERROR::
After a fresh install of PovRay on useraccount (with no admin-rights)
without errors, save POVLEGAL.DOC fails ("Cannot create POVLEGAL.DOC"),
arbitary file save fails (with crash), save settings fails and starting the
example generate the messages with error:
Support libraries used by POV-Ray:
  ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 6b, Copyright 1998 Thomas G. Lane
  LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Preset INI file is 'C:\PROGRAM FILES\POV-RAY FOR WINDOWS
V3.6\renderer\quickres.ini', section is '[512x384,
No AA]'.
Preset source file is 'C:\Program Files\POV-Ray for Windows
v3.6\scenes\objects\chesmsh.pov'.
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
/* THE ERROR */
Cannot open file C:\PROGRAM FILES\POV-RAY FOR WINDOWS V3.
\RENDERER\RERUN\CURRENT.INI to write rerun information
Parsing Options
  Input file: C:\Program Files\POV-Ray for Windows
v3.6\scenes\objects\chesmsh.pov (compatible to version
3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    C:\PROGRAM FILES\POV-RAY FOR WINDOWS V3.6\include
    C:\Windows\Fonts
Output Options
  Image resolution 512 by 384 (rows 1 to 384, columns 1 to 512).
  Output file: C:\Program Files\POV-Ray for Windows
v3.6\scenes\objects\chesmsh.bmp, 24 bpp (system
format)
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
Scene Statistics
  Finite objects:            2
  Infinite objects:          0
  Light sources:             2
  Total:                     4
File Init Error: Cannot open output file.
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
CPU time used: kernel 0.11 seconds, user 0.05 seconds, total 0.16 seconds
POV-Ray finished
Subject: Re: (SOLVED)
Date: 21 Nov 2008 19:23:33
Message: <49275105$1@news.povray.org>
Hello,
the bug belowe seems to doesn't arise on PovRay is V3.7.0.beta.mscv8.win64.
Greets and thanks
"news.povray.org" <Wol### [at] gmxde> schrieb im Newsbeitrag
news:4923eaca@news.povray.org...
> Hello
> ::TECH-INFO::
> ::ERROR::
> the example generate the messages with error:
> No AA]'.
> Redirecting Options
> /* THE ERROR */
> Parsing Options
> 3.61)
>  Library paths:
>    C:\Windows\Fonts
> Output Options
> format)
> Tracing Options
>  Quality:  9
> Scene Statistics
>  Finite objects:            2
>  Infinite objects:          0
>  Light sources:             2
>  Total:                     4
> POV-Ray finished
