POV-Ray : Newsgroups : povray.bugreports : Re: [patch] POVRay crash with parametric object Server Time
22 Oct 2025 14:19:11 EDT (-0400)
  Re: [patch] POVRay crash with parametric object (Message 1 to 1 of 1)
Subject: Re: [patch] POVRay crash with parametric object
Date: 23 Jun 2003 03:59:32
Message: <3ef6b364@news.povray.org>
OOPS, I was tricked by the success of my "solution" but the bug
is actually worse.
Wolfgang Wieser wrote:
> [cross-post: povray.bugreports]
> Rendering this test code, I can reliably crash POVRay.
> <snipped>
Still. Correct
> The bug may not show up on you box because of it's nature:
Correct.
> The reason for the bug is uninitialized static data (yeah...).
No. Initializing static data is never a bad idea but the actual
reason for the bug is something else:
In fpmetric.cpp, around line 430, the following code can be found:
                else
                        /* 1 copy */
                        if ((SectorNum[i] *= 2) >= Max_intNumber)
                                SectorNum[i] = Max_intNumber;
                        SectorNum[i + 1] = SectorNum[i];
                        SectorNum[i]++;
                        i++;     // <--- BUG!!
                        Intervals_Low[INDEX_U][i] = low_vect[U];
The bug is where I marked it: i is increased but there is no check
if it stays in range 0..31 as required by the array sizes of
Intervals_Low[][] and SectorNum[].
So, the code should be changed into something like:
                else
                        /* 1 copy */
+                       if(i>=31)
+                       {  Do something (break, continue, ...)  }
                        SectorNum[i]++;
                        i++;
I am pretty sure this is the actual reason for the bug because
test output showed the following values for i:
i=33
i=32
i=33
i=32
i=32
<crash>
Wolfgang
BTW, I still consider the check for SectorNum<0 in the Z component
calculation as unneeded.
