POV-Ray : Newsgroups : povray.bugreports : [patch] POVRay crash with parametric object Server Time
28 Jun 2026 10:54:08 EDT (-0400)
  [patch] POVRay crash with parametric object (Message 1 to 1 of 1)
Subject: [patch] POVRay crash with parametric object
Date: 23 Jun 2003 03:59:25
Message: <3ef6b35d@news.povray.org>
Rendering this test code, I can reliably crash POVRay.
#include "functions.inc"
global_settings { assumed_gamma 2.2 }
light_source { <0,1,0>*20, rgb <2,2,2>/2 }
light_source { <0.2,1,-0.8>*20, rgb <2,2,2>/1.7 }
#declare m=3;
parametric {
        function { u*sin(v) }
        function { 15*sqrt(pow(sin(m*v)*sin(u/2)/3,2)+
                pow(cos(m*v)*m/u*sin(u/2)/3,2)) }
        function { u*cos(v) }
        <0.001,0>, <15,2*pi>
        contained_by {  sphere { 0, 15 }  }
        precompute 12 x,y,z
        accuracy 0.000001
camera {  location <0,0.3,-1>*8.3 up y  look_at <0,0,0> }
The system in question is a Linux-ix86 (AthlonXP) box, compiler
is GCC-3.2.
The bug may not show up on you box because of it's nature:
The reason for the bug is uninitialized static data (yeah...).
The following patch will fix it:
diff -urN povray-3.50c/src/fpmetric.cpp povray-3.50c-ww/src/fpmetric.cpp
--- povray-3.50c/src/fpmetric.cpp       2003-01-07 02:08:27.000000000 +0100
+++ povray-3.50c-ww/src/fpmetric.cpp    2003-06-20 23:29:54.000000000 +0200
@@ -124,7 +124,8 @@
 static int PrecompLastDepth;
 static DBL Intervals_Low[2][32], Intervals_Hi[2][32];
-static int SectorNum[32];
+static int SectorNum[32]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
+                          0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
@@ -357,7 +358,7 @@
                /* Z */
-               if ((SectorNum[i] < MaxPrecompZ) && (0 < SectorNum[i]))
+               if (SectorNum[i] < MaxPrecompZ)
                        low = PData->Low[2][SectorNum[i]];
                        hi = PData->Hi[2][SectorNum[i]];
The first chunk simply sets up the static data to sane values.
It is important that these values are non-negative.
The second patch should be reviewed before getting applied.
It removes the check for SectorNum[i] being larger than 0.
The reason why I am including it here is that this looked to me as
if somebody did the most trivial patch for the problem I encountered
but it just cures the symptome, not the bug itself.
Looking at the code, there is no way how SectorNum[i] could get
negative.
Furthermore, the X and Y components do not have such a check,
only the Z component calculation does. Looks odd to me.
The only thing one should consider is that the check will prevent
SectorNum==0 from passing. I see no reason why this would be necessary
but experts should verify that.
Wolfgang
P.S. The code I've just read is a masterpiece of "code duplication".
That's not exactly good and tends to introduce bugs...
Should I post a patch...?
