POV-Ray : Newsgroups : povray.bugreports : UV mapping BUG Server Time
16 May 2026 19:57:31 EDT (-0400)
  UV mapping BUG (Message 1 to 1 of 1)
Subject: UV mapping BUG
Date: 18 Jun 2003 16:34:13
Message: <3ef0ccc5$1@news.povray.org>
As reported and discussed in the povray.general group by Manuel
<man### [at] tinit> and Warp <war### [at] tagpovrayorg>.  Example
below by Warp:
  When the second 'uv_mapping' is uncommented in the code below,
instead of giving an error message, the pigment is reset (POV-Ray
warns that "No pigment type given").
  If the first 'uv_mapping' is now commented away, an error message
*is* issued ("No matching } in 'texture', uv_mapping found instead").
camera { location -z*8 look_at 0 angle 35 }
light_source { <-20,10,-150>, 1 }
box
{ -1,1
  texture
  { uv_mapping
    pigment { rgb 1 }
    //uv_mapping
    normal
    { gradient x 1
      slope_map { [0 <0,1>][.5 <1,0>][1 <0,-1>] }
      scale 1/16
  rotate y*45 rotate x*-20
