POV-Ray : Newsgroups : povray.bugreports : Bug in #default directive parsing Server Time
28 Jun 2024 02:18:39 EDT (-0400)
  Bug in #default directive parsing (Message 1 to 1 of 1)
Subject: Bug in #default directive parsing
Date: 8 Mar 2001 18:37:32
Message: <3aa817bc@news.povray.org>
Hi all.
There's a bug in the #default directive parsing, that may be put in
evidence with the following code:
#declare Use_Rad = off;
#if (Use_Rad = off)
#debug "\nUse_Rad = off\n"
#default { texture { finish { ambient 0.4 diffuse 0.6 } } }
#else
#debug "\nUse_Rad = on\n"
#default { texture { finish { ambient 0.0 diffuse 1.0 } } }
  location <1, 2, -6>
  look_at <0, 1, 0>
plane { y, 0
    pigment { checker color rgb 0, color rgb 1 }
sphere { y, 1
    pigment { color rgb <1, .2, .2> }
light_source { <10, 10, -10>, color rgb 1 }
Whether Use_Rad is on or off, the default texture applied is always the
seconde one.
Vahur Krouverk found that the bug is in tokenize.c:
    CASE (DEFAULT_TOKEN)
+      if (Skipping)
+          UNGET
+          EXIT
+      else
          Parse_Default();
          EXIT
    END_CASE
The lines with a "+" must be added to correct the bug.
He also saw that this bug is present with INIT_SPLINE_TOKEN, etc...
Bye.
Bouf.
