Height fields seem to transmit light when the smooth-attribute is set. It
was suggested in povray.advanced-users that this may be related to the double
illumination bug in bicubic_patch, so I included a little patch for reference.
It might also be of interest that this bug can be reproduced in MegaPov 0.4
for Windows.
hf.gif is available in povray.binaries.images:
Subject: hf.gif for a post in p.b.a-u
Date: Sun, 30 Apr 2000 18:21:35 +0200
System:
Microsoft Windows 95, 4.00.950 B, Pov-Ray 3.1e
RedHat Linux 6.1, Pov-Ray 3.1g
AMD K6 233@250
128 MB PC100 SDRAM
#version 3.1;
plane { y,0.01 pigment {rgb 0}}
camera { location <0.01,0.01,-3> look_at 0 }
light_source { <0,1,10>, 1 } // light above plane
light_source { -<0,1,10>, 1 } //light below plane
background { rgb .1 }
#declare Tex= texture {
pigment { color rgb <.4,.2,0> }
finish {ambient 0}
//finish {specular .4 roughness .1}
bicubic_patch {
type 1 flatness 0.0100 u_steps 3 v_steps 3,
<-1, -1, 0>, <-1, -1, 0>, <0, -1, 0>, <1, -1, 0>,
<-1, -1, 0>, <-1, -1, 1>, <0, -1, 1>, <1, -1, 0>,
<-1, 0, 0>, <-1, 0, 1>, <0, 0, 1>, <1, 0, 0>,
<-1, 1., 0>, <-1, 1, 0>, <0, 1, 0>, <1, 1, 0>
scale .5
texture {Tex}
// lit from behind:
height_field { // top left
gif "hf.gif"
smooth // <-- commenting out this makes it appear black as it should
translate -.5
rotate 90*x
texture {Tex}
translate <-.6,.6,0>
height_field { // top right
gif "hf.gif"
//smooth
translate -.5
rotate 90*x
texture {Tex}
translate <.6,.6,0>
// lit from front:
height_field { // bottom left
gif "hf.gif"
smooth
translate -.5
rotate 90*x
texture {Tex}
translate <-.6,-.6,0>
height_field { // bottom right
gif "hf.gif"
//smooth
translate -.5
rotate 90*x
texture {Tex}
translate <.6,-.6,0>
