![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The color at the end of this cylinder appears undefined, although if I
understand the documentation correctly, it should be Red. Can anyone else
verify this result?
Please e-mail me directly, since I don't check the news very often.
thanks.
Download 'gradient_bug.pov.txt' (1 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Carl Osterwisch <cos### [at] biocom arizona edu> wrote:
: The color at the end of this cylinder appears undefined, although if I
: understand the documentation correctly, it should be Red. Can anyone else
: verify this result?
: Please e-mail me directly, since I don't check the news very often.
This is NOT the right place for asking "is this a bug?".
I haven't checked if this is a bug or not, but this article should
definitely have been sent to povray.general or .newusers or other similar,
not here.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 5 Aug 1999 10:49:03 -0400, "Carl Osterwisch"
Hi, Carl. Please read, "How to post bug reports", in the group
povray.announce.frequently-asked-questions.
After you have read that message, please then read, "Where can I post my
binary or text file?", which may be found in the same group, p.a.f-a-q.
Thank you for helping keep our newsgroup organized.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Carl,
the gradient pigment spans from one end of the cylinder to the other.
In a perfect world this would be just fine, but precision errors yield
the result you are seeing. POV finds the surface of the cylinder to be
something like z - A_Very_Small_Error and the pigment is found to be z
+ Another_Very_Small_Error, and these errors are random, so you see a
spotted surface. This is a variation of the coincident surfaces
problem, see Warp's VFAQ.
Here're several solutions of the problem:
a) scale the gradient pigment a bit up, like scale 1.00001
b) use the planar or marble pigments instead of gradient
c) scale down the cylinder a bit (like 0.999999) before applying the
pigment
HTH.
Peter Popov
ICQ: 15002700
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
