There seems to be a bug in the various noise functions. It exhibits itself as
banding after a certain _negative_ distance, along any axis, from the origin.
This distance varies depending on the noise function: it is around 78.125 for
1/f noise (granite), 312.5 (78.125*4) for DNoise and Agate noise, and around
10000 for Perlin noise (bozo, bumps, spotted).
Furthermore, in 1/f and DNoise the bug seems to become more pronounced at
78.125*2 and 78.125*4
Versions: POVWin 3.1g (Watcom and VC compile), POV Superpatch (3.1e codebase).
The problem was also reported to exist on 3.01r1.watcom
System: Celeron, 128MB RAM, Win98
//BEGIN EXAMPLE SCENE
camera{
orthographic
location y*5
up y*5*.75 right x*5
look_at 0
//1/f noise (granite)
#declare Tex1=
pigment{
granite
color_map{[0 rgb 0][1 rgb 1]}
translate 78.13*x //First signs of banding
//translate 156.25*x //More pronounced
//translate 312.5*x //Even more pronounced
scale 5
//Perlin noise (Bozo & Bumps & Spotted)
#declare Tex2=
pigment{
bozo
translate 10000*x
scale 1
//DNoise (turbulence)
#declare Tex3=
pigment{
gradient x
translate 312.5*x //Banding starts
//translate 625*x //Becomes more pronounced
scale 1
turbulence 1
//Agate turbulence
#declare Tex4=
pigment{
agate
scale 5
plane{
y,0
pigment{Tex1}
finish{ambient 1}
It is also now reported to be evident in Pov v2.2.ibmibc copyright date 1993.
If it is a bug it has existed for quite some time now.
Ken Tyler
I do not consider a precision problem a bug.
You always choose a precision deliberately while bugs are unintentional.
The problem is in texture.c, at the top:
/* Ridiculously large scaling values */
|#define MINX (-10000)
|#define MINY MINX
|#define MINZ MINX
The noise function only works in positive domains, so it first translates
your coordinate by -<MINX, MINY, MINZ> before computing noise. As you can
see, this breaks at -10000. Granite breaks at such a low offset because of
this:
| VScale(tv1,EPoint,4.0);
| for (i = 0; i < 6 ; freq *= 2.0, i++)
| VScale(tv2,tv1,freq);
| temp = 0.5 - Noise (tv2);
As you can see, your sample point will be scaled by up to a factor of 128.
Surprise, surprise: 10000/128=78.125. Obviously, the larger your sample
point is, the more iterations of the 1/f code will be over 10000. If you
determined this by experimentation, I'm impressed. :)
The fix is clearly to modify MINX and recompile. Why it's set so low is
anybody's guess.
>anybody's guess.
Silly me, I should read all the groups before I respond to a post in
.bugreports. :)
A workaround, obviously, is to translate your texture to somewhere
positive.
