![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
According to the change log for 3.1g, the average normal bug was fixed
some time before 3.1e.
I tried the scene file which I included with my first report of this bug
and the bug is still there.
// test file for average normal bug
camera{ right 4/3*x direction z*3 location <0,-.5, -28> look_at
<0,-.5,0> }
light_source{ <1000,2000,-5000> White }
#declare Norm1 = normal{radial .5 frequency 16 scallop_wave}
#declare Norm2 = normal{ average normal_map{[1 Norm1]}}
#declare Obj1 = cylinder{-y,y,1 pigment{White} normal{Norm1}}
#declare Obj2 = cylinder{-y,y,1 pigment{White} normal{Norm2}}
object{ Obj1 translate <-1.5,1.5,0> }
object{ Obj1 rotate z*180 translate <1.5,1.5,0> }
object{ Obj2 translate <-1.5,-1.5,0> }
object{ Obj2 rotate z*180 translate <1.5,-1.5,0> }
union{ //arrow pointing at faulty obj
cone{ <1.5,-3,0>,0, <1.5,-3.5,0>,.5 }
cylinder{ <1.5,-3.5,0>,<1.5,-4,0>,.25 }
scale<1,1,.1>
pigment{White}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This would be a different average normal bug. And this one's not just with
the average, but also with any patterened normal. Change Norm2 to:
#declare Norm2 = normal{ bozo normal_map{[0 Norm1][1 Norm1]}}
and you'll still see the problem.
-------- the next section is for programmers ---------
From what I can gather, The bug is in how warps (transformations)
are applied in relation to the Pyramid_Vect[] vectors that are used for
triangulating the normal from the slope_map.
In a patterend or averaged normal, the warps are applied, then
Pyramid_Vect[] is added into EPoint.
In a non-patterened normal, Pyramid_Vect[] is added to EPoint first, then
the warps are applied (inside Evaluate_TPat()).
All of this happens inside the function Perturb_Normal() in NORMAL.C.
I'd work more on a fix but it's getting late (and I can't skip work).
I just checked and this *is* the cause of the problem. No fix yet,
though... I just forced non-patterend normals to exhibit the same
problem on my system. ;-)
-Nathan
> <0,-.5,0> }
> scale<1,1,.1>
> pigment{White}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
