POV-Ray : Newsgroups : povray.bugreports : String parameters in macros do not return value Server Time
22 Oct 2025 17:07:58 EDT (-0400)
  String parameters in macros do not return value (Message 1 to 3 of 3)
Subject: String parameters in macros do not return value
Date: 1 Jun 1999 17:24:31
Message: <3754417f.0@news.povray.org>
I can't get string parameters to return a value.  I'm pretty sure I should
be able to do this.  See code for the example:
// Example start
#macro TestString(String)
    // This line should change the parameter, it does not, it only changes
the local value !!!
    #declare String = "Bye Now!"
#macro TestFloat(Float)
    // This line changes the parameter as expected.
    #declare Float = 123.4;
// Works as expected
#local MyFloat = 5;
TestFloat(MyFloat)
#debug str(MyFloat,1,1)
// Does not work as expected
#local MyString = "Hello"
TestString(MyString)
#debug MyString
#debug "\n"
sphere {1,1}   // So the engine doesn't complain...
// Example end
Output is:
123.4Hello
Should be:
123.4Bye Now!
I work on Windows NT on the standard binaries.
Subject: Re: String parameters in macros do not return value
Date: 2 Jun 1999 10:39:15
Message: <37553403.0@news.povray.org>
Samuel van Egmond <sam### [at] infabcom> wrote:
: #macro TestString(String)
:     #declare String = "Bye Now!"
: #end
: #local MyString = "Hello"
: TestString(MyString)
: #debug MyString
  A workaround could be:
#macro TestString()
    "Bye Now!"
#local MyString = TestString()
#debug MyString
Date: 2 Jun 1999 17:07:52
Message: <37558f18.0@news.povray.org>
thanks, but this was just the simple version, I tried to use this in a
recursive macro where the string parameter gets 'eaten' one character at the
time.  I've already got a work around by not using a parameter but a global
#declare.  Just thought I'd better put in a bug report so others would not
spend the same time figuring out why their macro doesn't work.
Nieminen Mika wrote in message <37553403.0@news.povray.org>...
>: #end
>: #debug MyString
>#macro TestString()
>    "Bye Now!"
>#end
>#debug MyString
