![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I had some strange rendering problemsw hen rendering a scene with an
object like this :
#declare MyObject1 = difference {
cylinder { <0.0,-0.07, 0.0>, <0.0, 0.07, 0.0>, 85.935 }
cylinder { <0.0,-1.00, 0.0>, <0.0, 1.00, 0.0>, 85.815 }
It looks like someone has cut some part of the 'sides' of the cylinder.
The endcaps are O.K., but it looks like two disks instead of a solid
ring.
This object is used within a pretty complex CSG, but the same problem
exists when rendering the object on its own.
When the ratio of radius to hight is > +/- 500, the problem disapears.
I had to solve this by using a higher cylinder and cutting the ring with
a plane :
#declare MyObject2 = difference {
cylinder { <0.00,-0.07, 0.00>, <0.00, 5.00, 0.00>, 85.935 }
cylinder { <0.00,-1.00, 0.00>, <0.00, 6.00, 0.00>, 85.815 }
plane { y, -0.07 }
It should be seen with a little scene like this :
location <-0.5, 0.5, 0.5>
look_at <0.0, 0.0, 0.0>
light_source {
<-5.0, 5.0, 5.0>
color rgb <1.0, 1.0, 1.0>
object { MyObject1 //PROBLEMS !!!!!
// object { MyObject2 //PROLBLEM SOLVED !!!!!
pigment { color rgb <1.0, 1.0, 0.5> }
transform -85.875*y
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What a mistake to make :
When the ratio of radius to hight is < (SMALLER !!!) +/- 500 the problem
disapears.
> object like this :
> ring.
> a plane :
> plane { y, -0.07 }
> camera {
> light_source {
> <-5.0, 5.0, 5.0>
> transform -85.875*y
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I didn't find anything wrong. Your example Object2 to correct the
supposed problem is wrong. At least it isn't the same as the Object1,
since it is leaving the upper y (wider section) instead of doing what
the first seems to be intended to do.
May just be your perspective of the shape and thinking of it
incorrectly. You simply have a very thin cylinder, very short in height
and large in diameter. To get the same for Object2 you would need a
plane {-y,-0.07} not what you have there. Hope this is right anyway, I
lost my first message reply.
> disapears.
> > object like this :
> > ring.
> > a plane :
> > plane { y, -0.07 }
> > camera {
> > light_source {
> > <-5.0, 5.0, 5.0>
> > transform -85.875*y
mailto:inv### [at] aol com?Subject=PoV-News
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
