POV-Ray : Newsgroups : povray.bugreports : #debug, #render ... windows Server Time
17 Nov 2025 11:54:05 EST (-0500)
  #debug, #render ... windows (Message 1 to 7 of 7)
Subject: #debug, #render ... windows
Date: 26 Mar 1999 07:01:52
Message: <36FB7624.22B06813@bahnhof.se>
I belive I have foundd a bug, or at least a minor irritation in the windows
version of pov-ray.
appearance :
in a very slow loop I have(some 140 000 items) I wanted a percentage meter, and
thus I made a #if(mod(Y,N/10)=0) #debug "." #end
statement(this isn't the real one, I actually had a bit more optimized code, as
well as some statistics) but to my irritation, a line isn't updated with new
output unless I add a "\n" to the output. I really didn't want to output
everything to a new line, but this seems impossible. I've tried with
#debug
#render
#statistics
#warning
by obvious reasons, #error isn't very appropiate .-)
version of POV :
Version 3.1e.watcom.win32 [Pentium II optimized]
I don't know if this is some optimization, to output to a line only when it is
full, but either a addition to the help files(that this is the case) or a
software addition.
Thankyou.
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Subject: Re: #debug, #render ... windows
Date: 26 Mar 1999 08:14:54
Message: <36fb884e.0@news.povray.org>
Spider <spi### [at] bahnhofse> wrote:
: but to my irritation, a line isn't updated with new
: output unless I add a "\n" to the output.
  This means that the outputting is buffered, just like outputting to
standard output in any programming language.
  In programming languages the solution to this is to flush the stdout
stream after outputting the text. AFAIK there's no way to flush text
streams in povray other than outputting a "\n".
  How about a new feature: #flush <stream>, where <stream> can be
'debug', 'render', 'warning', etc...
  For example:
#warning "This is a warning"
#flush warning
Date: 26 Mar 1999 09:13:17
Message: <36fb95fd.0@news.povray.org>
In article <36fb884e.0@news.povray.org> , Nieminen Mika <war### [at] cctutfi>
It is not, at least not in the POV-Ray core code.  The code used will work
on most other platforms that output the text directly. However, the GUI
platforms need to workaround certain limitations of text streams.
We are aware of the shortcomings of the current text stream only based
output when using graphical user interfaces. This will all work much better
in future versions of POV-Ray.
>   For example:
> #flush warning
     Thorsten
Date: 26 Mar 1999 18:22:42
Message: <36FC15C0.C6AABD96@bahnhof.se>
Ok, thanks. I guessed that it was this, but i was uncertain.
> >   For example:
> > #flush warning
>      Thorsten
//Spider
                "Marian"
Date: 26 Mar 1999 18:23:34
Message: <36FC15F4.16F870D5@bahnhof.se>
yeah, I know. I posted that solution as well, but I don't WANT to.
As well, the \t (i think) for TAB isn't working in windows.
>   For example:
> #flush warning
Just do direct output...
//Spider
                "Marian"
Date: 10 Apr 1999 14:58:56
Message: <370f8756.26362743@news.povray.org>
>version of pov-ray.
>appearance :
>#debug
>#render
>#statistics
>#warning
>version of POV :
>software addition.
>Thankyou.
This is not a bug in any case. That's just how windoze treats console
output. You may try to use \r which is a carriage return. This will
flush the stream or whatever you programmers call it. I have
successfully used it for the exact same purpose as you, and I remember
it was quite simple. You need a string (eg. yourString) containing 100
dots '.' and then, every time you advance a percentage in your loop,
use something like
 #debug concat ("\r", substr(yourString, 1, currentProgress))
and that's all. HTH.
Peter Popov
ICQ: 15002700
Date: 11 Apr 1999 11:58:04
Message: <3710B76F.EA3BE6B8@bahnhof.se>
> use something like
hey, you be back. Good :-)
Thanks for the info :-)
//Spider
                "Marian"
