![](/i/fill.gif) |
/* I believe that I have found a bug in POV-Ray.
* I tested this several times in POV-Ray 3.1a.watcom.win32. I am using
* Windows 95 v4.00.950 (C build) with Internet Explorer 4 installed.
* The actual computer I built myself, so it has no manufacturer; it is
* running an AMD K6-II at 333MHz with 64Mb of RAM. The only programs I
* have running are: POV-Ray, Windows Help (with the POV-Ray docs
* loaded), the CD Player (playing), and an MS-DOS Prompt, with nothing
* running within.
* I have no GUI-Extensions loaded.
* This is what I have found:
* When the angle on the rotation below is less than (not equal to) 90,
* the green triangle below will not be displayed. (With d set to 1/3,
* the three triangles should form a larger, equilateral triangle.)
* With the rotation at 90 or greater, it works fine. If I change the
* union to a mesh (and move the pigments out of the triangles,
* obviously), it works fine. If I comment out either of the other two
* triangles, the green triangle will be displayed. I have checked, and
* all three triangles' vertices are specified in the same direction.
* (Clockwise or counterclockwise, depending where you look from.) (Not
* that that should have any effect, but it normally does in realtime 3D
* renderers.)
* Please excuse the formatting on the scene.
* Note that this scene is meant to be rendered at a square aspect
* ratio. The bug does exhibit itself with a 4:3 aspect, however.
camera { orthographic location <0, 0, -1> direction z up y right x }
light_source { <2e15, 2e15, -2e15> color rgb <1, 1, 1> }
#declare d = 1/3;
union
triangle {< d,-d,-d>,< 0,-1, 0>,< 0, 0,-1> pigment{color rgb<1,0,0>} }
triangle {< 1, 0, 0>,< d,-d,-d>,< 0, 0,-1> pigment{color rgb<0,1,0>} }
triangle {< 1, 0, 0>,< 0,-1, 0>,< d,-d,-d> pigment{color rgb<0,0,1>} }
rotate 89*y
scale .5
![](/i/fill.gif) |
![](/i/fill.gif) |
Ben Olmstead/BEM wrote in message <36F4000C.AD914AA8@mad.scientist.com>...
<snip>
> * renderers.)
<snip>
I seem to be able to render the green triangle fine at all rotations. I'm
using Windows 95 POV3.1e. Perhaps the problem is one of shading (since I
think the default is to have an ambient finish of zero?) - have you tried
using textures with an ambient value of 1, just to check this? Or perhaps
have a bright background, so at least the shadow could be seen ? Though I
used exactly the same shape, I did use my own camera and light definitions
(yours did not appear to show any of the shape regardless!)
Matt
![](/i/fill.gif) |
