POV-Ray : Newsgroups : povray.bugreports : Blob lighting bug Server Time
28 May 2024 15:41:21 EDT (-0400)
  Blob lighting bug (Message 1 to 3 of 3)
Subject: Blob lighting bug
Date: 1 Jan 1999 11:15:14
Message: <368cf492.0@news.povray.org>
I think I found a bug in povray regarding to blob lighting calculation.
  The pov-code showing the bug is the following:
camera { location <0,50,-40> look_at 0 angle 35 }
light_source { <100,200,-100> 1 }
blob
{ threshold .1
  sphere { -y*1000,1209,1 }
  sphere { -y*5,10,.006 }
  pigment { rgb <1,0,0> } finish { specular .5 }
  The result can be seen at:
http://www.cs.tut.fi/~warp/blobtst1.jpg
  The second (smaller) blob component renders just fine but the first
component renders obviously bad (the bug has nothing to do with the second
blob component, but I just put it there to show more clearly the bug in the
first component).
  I extensively studied this bug.
  The bug depends on:
  1) The position of the camera.
     If we move the camera, the bug effect changes position. For example,
if we set the y component of the camera to 40, ie:
camera { location <0,40,-40> look_at 0 angle 35 }
the result is:
http://www.cs.tut.fi/~warp/blobtst2.jpg
  2) The position of the light source.
     If we now move the light source a bit down, ie:
light_source { <100,70,-100> 1 }
the result is:
http://www.cs.tut.fi/~warp/blobtst3.jpg
  3) The number of light sources.
     If we add another light source, ie:
light_source { y*100, 1 }
we can see that the bug appears for each light source separately:
http://www.cs.tut.fi/~warp/blobtst4.jpg
  4) The radius of the blob components.
     If we change the radius of the first component to about 300, ie:
  sphere { -y*1000/4,1209/4,1 }
something very strange happens:
http://www.cs.tut.fi/~warp/blobtst5.jpg
  If we set the radius smaller than about 160, ie:
  sphere { -y*1000/8,1209/8,1 }
the bug completely disappears:
http://www.cs.tut.fi/~warp/blobtst6.jpg
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Subject: Re: Blob lighting bug
Date: 9 Jan 1999 13:44:52
Message: <3697a3a4.0@news.povray.org>
It should be nice to know if this bug is happening to anyone else, or is
it just me?
Date: 9 Jan 1999 14:57:51
Message: <366ED5FC.EDB96C11@Kopp.com>
I see the bug, too.  I'm not sure of the cause right now, though.
-Nathan
> it just me?
