POV-Ray : Newsgroups : povray.bugreports : animation rendering - page fault error closes pov Server Time
14 Jul 2025 05:05:51 EDT (-0400)
  animation rendering - page fault error closes pov (Message 1 to 2 of 2)
Subject: animation rendering - page fault error closes pov
Date: 28 Nov 1998 13:47:20
Message: <36604538.0@news.povray.org>
Hi anyone,
          I've been using pov-ray for a couple years now with great
satisfaction, until I recently downloaded version 3.1 and began a new
project with hopes of rendering a simple flower like shape. I began with a
primitive, just to get the feel. But when I try to animate the primitives
motion using the clock variable I always get a page fault error which closes
the application.
         Here's the problem causing code:
global_settings { assumed_gamma 1.0 }
// Look down at an angle at our creation
camera
  location  <0,1,-4.0>
  direction 1*z
  look_at   <0,0,0>
// Simple background for a simple scene
background { color rgb <0.9, 0.8, 0.7> }
// A light source
light_source { <20, 20, -10>  color White  }
#declare increment = 0.03;
#declare xd=0.0;
#declare yd=-2.0;
#declare zd=0.0;
#declare dd = 0.12;
#declare iclock=clock+0.01;
#declare fclock=5.0*(clock+0.01);
#declare tclock=2.0*(clock+0.01);
#declare td=3.5;
blob{
threshold 0.6
#while (yd<=1)
#declare td=td-0.014;
#declare xd=sin(yd*3.0+fclock)/td;
// #declare zd=sin(yd*2+tclock);
  cylinder { <xd,yd,zd>  <xd,yd+0.03,zd>, dd , 4 pigment { Red } }
  #declare yd=yd+increment;
  #declare dd=dd-0.0009;
sphere { <xd,yd+increment+.15,zd> ,.5,7
// image_map { tga "eye1.tga" }  rotate <0,-139.2,4+fclock> rotate <-70,0,0> scale 4
texture { pigment { Blue  } finish { roughness 0.3 } }
    This runs fine for between 2 and 10 renderings, then it throuws a page fault error
and an Access Violation 0xc0000005,  the debugger points out this bit of native code
as the problem:
00439E7D   add         esi,48h
00439E80   push        edi
00439E81   mov         eax,ecx
00439E83   shr         ecx,2
00439E86   repne movs  dword ptr es:[edi],dword ptr [es
i
0
0439E88   mov         cl,al
00439E8A   and         cl,3
00439E8D   repne movs  byte ptr es:[edi],byte ptr [esi]
         The line seperated by spaces is the one pointed to as the error
line.
        Does anyone know how to prevent this? am I missing something in the
coding?
        Any help would be greatly appreciated.
          Thanks,
            Guy :)E
Subject: Re: animation rendering - page fault error closes pov
Date: 30 Nov 1998 07:01:56
Message: <36628934.0@news.povray.org>
I ran your scene animation to 24 frames, no problems.
You need to state your OS (likewise POV platform)  and other relevent info,
like video, ram, etc.; esp. since you've posted to the bugreports group.
Message <36604538.0@news.povray.org>, Guy Giesbrecht  typed...
>Hi anyone,
>the application.
>camera
>  location  <0,1,-4.0>
>  direction 1*z
>  look_at   <0,0,0>
>// A light source
>#declare xd=0.0;
>#declare yd=-2.0;
>#declare zd=0.0;
>#declare dd = 0.12;
>#declare td=3.5;
>blob{
>threshold 0.6
>#while (yd<=1)
>#end
scale 4
fault
> error and an Access Violation 0xc0000005,  the debugger points out this bit
of
>native code as the problem:
>00439E80   push        edi
>00439E83   shr         ecx,2
>i
>0
>0439E88   mov         cl,al
>00439E8A   and         cl,3
>line.
>coding?
>          Thanks,
>            Guy :)E
  http://members.aol.com/inversez/POVring.html
=Bob
