Don't know if it's a bug..
I have a dual-P2-400 machine, using NT4; when I do a render POV only
uses 30% of the CPU; the max it could use is 50% (it's single threaded,
right?) but why doesn't use all the CPU he can get EVEN if priority is
set ti REALTIME?
Thanks
Lapo 'Dr.Brain' Luchini
mailto:lap### [at] usa net (PGP Key on keyservers)
http://lapo.home.ml.org (ICQ UIN: 529796)
What settings do you have for the GUI and RENDER priority ?
regards
Nathan O'Brien
no1### [at] no13 net
http://www.no13.net
> set ti REALTIME?
> Thanks
I tried high, highest, I even tried to set program priority to realtime using
taskManager.. but nothing..
Hmmmm....
The only other suggestion is to check for any TSR's.
regards
Nathan O'Brien
http://www.no13.net
It's just that is singel threaded. One thread running on a two
processor system can use up to 50% of processing power.
Try starting another rendering thread (i.e. 2xPOVray)
and the CPU should go up to 100%
It has nopthing to do with priotity or other TSRs running.
Markus
> set ti REALTIME?
> Thanks
