POV-Ray : Newsgroups : povray.bugreports : low CPU load Server Time
22 Nov 2024 18:57:24 EST (-0500)
  low CPU load (Message 1 to 5 of 5)
Subject: low CPU load
Date: 3 Oct 1998 05:54:37
Message: <3615E648.1EB122CA@usa.net>
Don't know if it's a bug..
I have a dual-P2-400 machine, using NT4; when I do a render POV only
uses 30% of the CPU; the max it could use is 50% (it's single threaded,
right?) but why doesn't use all the CPU he can get EVEN if priority is
set ti REALTIME?
Thanks
Lapo 'Dr.Brain' Luchini
mailto:lap### [at] usanet (PGP Key on keyservers)
http://lapo.home.ml.org (ICQ UIN: 529796)
Subject: Re: low CPU load
Date: 4 Oct 1998 04:19:44
Message: <36171F56.F7931CD8@no13.net>
What settings do you have for the GUI and RENDER priority ?
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
> set ti REALTIME?
> Thanks
Date: 5 Oct 1998 19:23:17
Message: <361946D1.ECBC0B64@usa.net>
I tried high, highest, I even tried to set program priority to realtime using
taskManager.. but nothing..
Date: 8 Oct 1998 06:36:18
Message: <361C8522.17FCA6EA@no13.net>
Hmmmm....
The only other suggestion is to check for any TSR's.
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
Date: 3 Dec 1998 08:19:22
Message: <36668FCA.191D74C5@zess.uni-siegen.de>
It's just that is singel threaded. One thread running on a two
processor system can use up to 50% of processing power.
Try starting another rendering thread (i.e. 2xPOVray)
and the CPU should go up to 100%
It has nopthing to do with priotity or other TSRs running.
Markus
> set ti REALTIME?
> Thanks
