![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This problem greatly decreases the value of the #local declaration: you
can't have a local identifier with a different data type from a same-named
global identifier.
e.g. you can't:
(main file) #declare anItem=4;
(include file) #local anItem="test"
This restriction should be at least signaled in the final docs...
POV INFO
POV-Ray for Windows
Version 3.1.beta.6b.watcom.win32 [Pentium II optimised]
SYSTEM INFO
MS Windows 95 4.00.950 B
IE 4.0 4.711712.6
Pentium Pro 233MHz
128MB RAM
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> global identifier.
> e.g. you can't:
This feature also exists in 3.1.watcom.win32.r1 ( Windows 95 ).
Note doing an #undef anItem before #local prevents the error
message.
An example of an error-generating file :
------- local_test.pov -------------
#declare a = pigment { color rgb 0.5 }
#include "local_test.inc"
camera { location 3 look_at 0 }
light_source { 4 color 1 }
sphere { 0, 1 pigment { a } }
------- local_test.inc -------------
#local a = 4; // this line generates an error
Dan
PII 128MB W95
http://www.flash.net/~djconnel/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello
Dan Connelly wrote in message <360CDC9A.FA6A3850@flash.net>...
>message.
Yes, of course it does... to be on the safe side, you can even add something
like
#ifdef (anItem)
#local thrulyImprobableName_dkjgglk=anItem
#undef anItem
<some code>
#undef anItem
#ifdef(thrulyImprobableName_dkjgglk)
#declare anItem=thrulyImprobableName_dkjgglk
BUT, apart from being tedious, (and eventually fucking up the anItem true
scope) this does not keep what I thought to be the main advantage of #local:
the opportunity to use any name in generic #include files.
Don't misunderstand me: I do not complain - I explain. Pov is really good
and I really apreciate #local much as it is. I hope this slight restriction
will be indicated in the final manual.
Povingly,
Philippe
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Philippe Debar <phi### [at] hotmail com> wrote:
: #local thrulyImprobableName_dkjgglk=anItem
This doesn't work if 'anItem' is anything but a float or a vector. For
example, if it's a texture it have to be inside a texture{} block.
This in pov3.02 (I have no 3.1 right now to test, so maybe it have
changed?).
I think this is a deficiency.
- Warp. -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Phillippe:
My reply wasn't intended to provide a suggestion to you.
Rather, I was stating for the record my observations.
One might expect that #undef before #local would
have no effect.... and if the latter is broken,
perhaps the former is as well.
This group is not the correct forum for me to discuss
how you should write your POV code.
The implementation of local scope is, I think, flawed.
My reading of the source code is that the way it is done (in parse.c)
is to save the old variable as a temporary variable but use
the old definition as a template for the new definition.
I think it would be better to forget about the old
symbol table reference :
1. rename the old symbol to a temporary name
2. create a new symbol table entry in the current
scope "from scratch"
I agree this "feature" seriously comprimises the
abstraction offered by the #local construct.
Dan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
