POV-Ray : Newsgroups : povray.bugreports : Codemax Properties Problem Server Time
22 Nov 2024 19:30:48 EST (-0500)
  Codemax Properties Problem (Message 1 to 2 of 2)
Subject: Codemax Properties Problem
Date: 25 Sep 1998 04:06:36
Message: <360B40E7.7B49442C@bellsouth.net>
Hi Chris and company!
Just wanted to let you know that the bug I reported a couple of weeks
ago on beta6 and 6b is still present in PovWin3.1R1, I have attached
that report incase you can not find it.
Again Thanks for the great program, and effort to make it better.
------------Original report---------------
First off Great job on the new features!
Secondly I have a bug to report.
I have a Pentium II 400Mhz with 128Mb. Win 95c
Open any text file:
Select Editor:Codemax Properties:Keyboard (TAB)
This results in the following Error
"Access violation at address 00E584EB in module 'CMAX101.DLL' READ of
address FFFFFFFF"
Select "OK" in the error box.
In the Codemax Properties box selecting cancel or the close button does
nothing, selecting one of the other tabs or the OK button gives a page
fault in CMAX.
This page fault info is from selecting OK. The other tabs give page
faults at slightly different locations.
PVENGINE caused an invalid page fault in
module CMAX101.DLL at 014f:00e56ea6.
Registers:
EAX=00000000 CS=014f EIP=00e56ea6 EFLGS=00010206
EBX=bff64db6 SS=0157 ESP=0073f36c EBP=00000000
ECX=00000018 DS=0157 ESI=0073f4b0 FS=2a9f
EDX=00e56ea6 ES=0157 EDI=5e5fe98e GS=0000
Bytes at CS:EIP:
8b 4d 70 8d 54 24 38 80 e5 7f 52 80 cd 40 6a 00
Stack dump:
0073f4b0 00008522 00000000 00000af0 00000000 00000000 83b40283 16af36d3
00000000 00000000 00000467 04670000 00000000 00000000 0000851c 0073f4e0
PS.
When I first found this problem the initial error occurd at 00E583D4.
One night I was playing around and the error did not occur. I do not
remember what was different then. I have been able to reproduce this
error 20+ times.
David Reynolds
Subject: Re: Codemax Properties Problem
Date: 10 Oct 1998 18:07:04
Message: <361fcc78.0@news.povray.org>
>Open any text file:
>address FFFFFFFF"
>fault in CMAX.
I have also experienced the same problem but the access violation  was at
1001858B.
I hope this will help.
Also I really like your new interface.
