POV-Ray : Newsgroups : povray.bugreports : 3.8 macro parsing errors : Re: 3.8 macro parsing errors Server Time
18 Jul 2026 00:09:56 EDT (-0400)
Date: 25 Jun 2024 14:57:13
Message: <667b1309@news.povray.org>
On 6/25/24 11:53, jr wrote:
> our" as in not just 'yuqk' ?  (because the wiki docs only mention 'float', and
> knowing it'll be a double is useful (I think))
I'm reasonably sure. :-)
It's true that the yuqk fork moved from the std::atof() function to
std::strtod() to enable better debugging on bad, but still sort of
getting converted strings. I wanted the debug compile of yuqk to return
detail on problems and not just continue onward with unintended values.
I believe both std::atof() and std::strtod() return doubles(*).
I'm not 100% sure what std::atof() might do on being passed "1.0f" say,
but it should be getting assign to a return double.
Suppose we have these two SDL lines where the first one is what we
intended and the second one is what we typed.
#debug concat("val(1.0123\") = ",str(val("1.0123"),19,17),"\n")
#debug concat("val(1.01 23\") = ",str(val("1.01 23"),19,17),"\n")
in v3.8 beta 2 or the non-debug compile of yuqk we get the following
output:
val(1.0123") = 1.01229999999999998  // (Example of str's noisy digits)
   (f_boom() %g returns 1.0123 with default rounding)
val(1.01 23") = 1.01000000000000001 // Oops
Where the debug compile of yuqk returns:
File 'HUGE_VAL.pov' line 46:
Parse Error:
Error during val call At: < 23> converting <1.01 23>
Value set to <1.01>
And wonder of wonders, I used the same test scene file I was using for
the +-inf stuff and my debug compile dies on:
#debug concat("val(\"inf\") = ",str(val("+inf"),19,17),"\n")
but not in val but due an additional check I inserted in our expression
parsing... Ideally at that check I would remember be smart enough to
trust that std::strtod()'s own parsing handles the infinities correctly.
I'd bet there is no easy way to do that with 100% certainly and still
prevent other +-inf things which are very likely problems.
I'll look, but currently, I'd say now you cannot use infinities at all
in the debug version of yuqk. Thanks jr & BW for the questions.
Off to again update the new rulesOfThumbForMath.txt file - or the code,
if I can figure out how to let only infinite double returns from val()
past by the debug compile checking for infinite values.
Bill P.
