POV-Ray : Newsgroups : povray.binaries.utilities : Polynomial Spreadsheet Server Time
25 Dec 2025 09:33:16 EST (-0500)
  Polynomial Spreadsheet (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Polynomial Spreadsheet
Date: 19 Oct 2017 18:42:58
Message: <59e92a72@news.povray.org>
> On 19/10/2017 20:31, Bald Eagle wrote:
>> Please test extensively and give feedback.
> When trying to open it in Excel I get:
> The file is corrupt and cannot be opened.
No problem using Libre Office 5
Maybe Exel have problems using ODS files.
Date: 19 Oct 2017 18:45:30
Message: <59e92b0a$1@news.povray.org>
Excuse me, but don't work here.
It opens without error, but it endlessly refresh itself.
Date: 19 Oct 2017 19:20:45
Message: <59e9334d$1@news.povray.org>
It is new install of Office 2013 and I've not set up many preferences
and options. So problems are most likely at my end.
Regards
Date: 19 Oct 2017 20:05:00
Message: <web.59e93cb563d226a55cafe28e0@news.povray.org>
Converted to Excel format.
Had to change my fancy exponent code because Excel still sucks.
Should at least work, even if the equation cell isn't as pretty  ;)
Download 'polynomial 1.0.xls.dat' (197 KB)
Date: 20 Oct 2017 02:59:01
Message: <59e99eb5$1@news.povray.org>
On 19-10-2017 21:31, Bald Eagle wrote:
> Version 1.0
Just for the sake of completeness: It opened without a glitch in
OpenOffice 4.1.3
Otherwise, I shall leave this alone. I do not have a mathematical mind :-)
Date: 20 Oct 2017 05:36:58
Message: <59e9c3ba$1@news.povray.org>
hi,
>> Version 1.0
> OpenOffice 4.1.3
also appears ok in v 4.0.0.3.
ibid.
regards, jr.
Date: 23 Oct 2017 09:45:00
Message: <web.59edf1a863d226a5c95fc4120@news.povray.org>
Open without problems with libreoffice 5.3.
When it comes to getting the results to Pov-Ray, that's when the trouble starts.
Is Kevin Bacon a universal constant now? According to the documentation, the
polynomial version of the syntax lacks the "command" parameter at first so that
the program starts processing. From the "function" version I lack experience to
know why it also gets stuck in the calculation. Greetings, and thank you for
sharing.
B. Gimeno
Date: 23 Oct 2017 10:15:00
Message: <web.59edf89463d226a5c437ac910@news.povray.org>
Good to hear.
Well, sort of.  ;)
but only for 6th-degree polynomials   :D
https://www.youtube.com/watch?v=n9u-TITxwoM
http://www.sixdegrees.org/
I'm not really sure what you mean by that.
it ought to be poly {
then a list of xyx (PowerX, PowerY, PowerZ):multiplier terms
> sharing.
It's certainly possible that there's a small typo or something in there.
I've had my hands full with a number of other things, but perhaps tomorrow I
will be able to review the spreadsheet and do some testing with scenes in
POV-Ray.
It would be easier for me debug anything or explain where your problems are if
you could post a short scene with the results of the spreadsheet that you copied
into the scene.
Thanks!
Date: 23 Oct 2017 12:55:08
Message: <web.59ee1ec263d226a5c437ac910@news.povray.org>
So, the idea is that you can just plug in values for the exponents in the
applicable terms, and the top cells with have a correctly formatted syntax for
the poly{} object:
poly {4, <9, r2*r2, 1, -123, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, constant>}
or the polynomial {} object with the 'easy' syntax:
polynomial {xyz(4,0,0):9, xyz(3,1,0):r2*r2, xyz(3,0,1):1, xyz(3,0,0):-123,
xyz(2,2,0):1, xyz(2,1,1):1, xyz(2,1,0):1, xyz(2,0,2):1, xyz(2,0,1):1,
xyz(2,0,0):1, xyz(1,3,0):1, xyz(1,2,1):1, xyz(1,2,0):1, xyz(1,1,2):1,
xyz(1,1,1):1, xyz(1,1,0):1, xyz(1,0,3):1, xyz(1,0,2):1, xyz(1,0,1):1,
xyz(1,0,0):1, xyz(0,4,0):1, xyz(0,3,1):1, xyz(0,3,0):1, xyz(0,2,2):1,
xyz(0,2,1):1, xyz(0,2,0):1, xyz(0,1,3):1, xyz(0,1,2):1, xyz(0,1,1):1,
xyz(0,1,0):1, xyz(0,0,4):1, xyz(0,0,3):1, xyz(0,0,2):1, xyz(0,0,1):1,
xyz(0,0,0):constant}
or if you wanted to use the equation in a function, for an isosurface, then
that's available too:
#declare Polynomial = function {(9 * pow(x,4)) + (r2*r2 * pow(x,3) * y) +
(pow(x,3) * z) + (-123 * pow(x,3)) + (pow(x,2) * pow(y,2)) + (pow(x,2) * y * z)
+ (pow(x,2) * y) + (pow(x,2) * pow(z,2)) + (pow(x,2) * z) + (pow(x,2)) + (x *
pow(y,3)) + (x * pow(y,2) * z) + (x * pow(y,2)) + (x * y * pow(z,2)) + (x * y *
z) + (x * y) + (x * pow(z,3)) + (x * pow(z,2)) + (x * z) + (x) + (pow(y,4)) +
(pow(y,3) * z) + (pow(y,3)) + (pow(y,2) * pow(z,2)) + (pow(y,2) * z) +
(pow(y,2)) + (y * pow(z,3)) + (y * pow(z,2)) + (y * z) + (y) + (pow(z,4)) +
(pow(z,3)) + (pow(z,2)) + (z) + constant}
and all you have to do is copy and paste whichever syntax you want.
In the above examples, obviously r2 and constant need to be previously defined
variable names in your scene.
Date: 24 Oct 2017 20:25:00
Message: <web.59efd8cb63d226a55cafe28e0@news.povray.org>
I checked out the results using the data for the torus in the docs, and I think
I see what you mean.  polynomial {} requires the order of the equation followed
by the rest of the data.  I made the edit, and it should work fine now. [version
1.0a]
> sharing.
> B. Gimeno
I'm not sure what you mean by "stuck" - does POV-Ray give you an error?
I had no problems when I copied and pasted the function into a scene:
#declare Polynomial = function {(pow(x,4)) + (2 * pow(x,2) * pow(y,2)) + (2 *
pow(x,2) * pow(z,2)) + (-104 * pow(x,2)) + (pow(y,4)) + (2 * pow(y,2) *
pow(z,2)) + (56 * pow(y,2)) + (pow(z,4)) + (-104 * pow(z,2)) + 784}
and then used that function in an isosurface:
isosurface {
 function {Polynomial (x, y, z)}
 accuracy 0.001
 max_gradient 4510
  contained_by {box {<-10, -4, -10>, <10, 4, 10>} }
  texture {pigment {DocPigment} finish {specular 0.2}}
} // end isosurface
I may see if I can work out some more refinements to make it a little easier to
use.  I could highlight the terms that need values (if they are non-zero) so
that it's easier to find the terms to edit.  There might also be a way for me to
consolidate the list of terms depending on the order - but that might take quite
a bit of tinkering.
Download 'polynomial 1.0a.ods.dat' (47 KB)
