POV-Ray : Newsgroups : povray.binaries.utilities : Announce: 3DWin 4.1, a 3D file format converter Server Time
10 Jun 2026 16:31:07 EDT (-0400)
  Announce: 3DWin 4.1, a 3D file format converter (Message 21 to 21 of 21)
Subject: Re: Announce: 3DWin 4.1, a 3D file format converter
Date: 27 Jul 2000 04:13:27
Message: <397fef26@news.povray.org>
In moray.win Steven Durham <ste### [at] earthlinknet> wrote:
:> 1 Euro dollar=1US dollar AFAIK
  1 Euro = 0.9423 US Dollar
Date: 22 Jul 2000 14:31:08
Message: <1cqjns0ar0l6s9untj2gocnpsnbknts6sf@4ax.com>
Hi Dennis McDaniel, you recently wrote in moray.win:
> Thanks for the suggestions, but yes, I've tried them all already.  In fact,
> I checked the message window in POV-Ray, and it says it can't find one of
> the .inc files.  But I've checked and everything is where it's supposed to
> be (\udo).  Go figure?!?
Have you done a View|Dependancies? If that command pops up message
boxes about missing files, then that's the problem. Just follow the
screen instructions to let Moray know where the files are.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 22 Jul 2000 18:03:08
Message: <397A19FD.FA816896@softcom.net>
Lutz,
Yes, I checked the references, and their all in place.  However, as I mentioned
to Thomas only slightly earlier in this thread, the problems I'm having now are
with a *_m.inc file which I believe is a material file created in 3D-Win.  Per
his suggestion, I moved the *_m.inc, the *_o.inc, and the *_p.inc files to the
\povscn directory and I was able to render the part.  However, it only renders
with the default white texture despite what I assign it in Moray.  If I export
the part from 3D-Win with the materials option unchecked (this doesn't create a
*_m.inc file), then it renders the scene, but without the .udo object displayed.
I don't get any missing materials errors, it just renders without the object.
Any suggestions?
By the way, Lutz.  I just want to tell you how much I enjoy using Moray.  I am a
mechanical designer and use a $4000 CAD program (SolidWorks 2000) every day.  But
I still sit down in the evenings and use Moray and POV-Ray for recreation.  Keep
up the good work.  Is there any way you could post on your website what we might
expect from the next version?
Thanks again, Lutz.
> - Lutz
Date: 22 Jul 2000 18:18:20
Message: <397A1E2D.6397106B@yahoo.com>
Dennis,
I have found exactly the same thing... rendering a "white android".. see a post of
mine in the POVray.general group.  I suspect that we are both using the demo register
key version and that the material/UV mapping feature is turned off even though the
options are apparently there in the interface. The release notes does state that
material import is only available in the registered version. I looked inside the
various include files generated and the UV data seems to be missing too.
My problem is that I really need to see the material import working to decide if I
want to register this program. The free earlier versions already import UDOs as one
mesh with no texture. I'm poor and I don't have the $40 or so to register just to see
if it works.
Dennis McDaniel wrote:
> Lutz,
> Any suggestions?
> Thanks again, Lutz.
> > - Lutz
