yesbird wrote:
> > Thanks for feedback, to fix GLB issue I need to add one more compression
> > feature.
> 'Crab Nebula.glb' works fine now ( see attachment), please try it again.
> YB
AsyncLoader.js:51 Error: THREE.GLTFLoader: No DRACOLoader instance provided.
at new GLTFDracoMeshCompressionExtension (GLTFLoader.js:1922:10)
at GLTFLoader.parse (GLTFLoader.js:400:37)
at Object.onLoad (GLTFLoader.js:245:11)
at three.module.js:44568:38
_onError @ GLTFLoader.js:225
AsyncLoader.js:37 Problem loading:
uploads/d91ecd2052b7fe17892df46e1a6d97a43a76a4f8/Crab Nebula.glb
yesbird wrote:
> The reason is multiple meshes, contained in this scene, but conversion
> is possible only for one. Merging all of them will produce complete
> model.
> YB
handling of multiple meshes would be a nice feature :)
Without it I have to learn how to convert the files first.
Your Website and the GUI of all2mesh looks nice.
Have checked it out, also the other tools.
Maybe some words about them, small description what they are doing?
And who has created them?
Do you know an online-tool to create textures for Povray?
I've already thought about programming something like this myself.
Greetings from Cologne,
Ma
On 02/10/2025 10:11, Maetes wrote:
>>> feature.
>> YB
Thanks for feedback, just checked - 'Crab Nebula.glb' still works
fine. Please try to clear browser's cache.
YB
No doubt, this is the first position in my TODO list :).
If you about https://yesbird.online/, then this is my portfolio,
"Yesbird studio" - it's me :). Tooltips will appear on cards hovering,
all (almost) applications have some help.
No, but it depends on what do you mean by 'textures for Povray' ?
As far as I know Povray uses ordinary bitmaps in image_map
instruction: https://www.povray.org/documentation/view/3.60/337/
Btw, I am going to implement a line of online tools for POV-Ray:
spline, prizm and SOR editors will be the first.
In this case you can check https://threejs.org - this is the great tool
with very friendly support.
Wish you good luck with it !
YB
Just now I posted an update to converter, that includes:
1. Load and export complete scene (all meshes contained in the file).
2. By advice of Paul Bourke, scene metrics at the top of model.inc file:
center and radius of bounding sphere, bounding box coordinates.
3. Wireframe model shading.
How to use:
All meshes in 'model.inc' have names surface*, numbered from 1.
At the end of the file there is a 'union', that combines them together.
//----------- Sample scene (attached) ----------------------------------
#version 3.7;
#include "model.inc"
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#declare cam = camera { perspective angle 55
location <RADIUS, RADIUS, RADIUS> * 1.5
right x * image_width / image_height
look_at CENTER}
camera{cam}
light_source{< 3000,3000,-3000> color rgb <1.0, 1.0, 1.0>}
Testing and any kind of feedback are highly appreciated :).
YB
Download 'scene.pov.txt' (1 KB)
Download 'model.inc.txt' (652 KB)
Download 'scene.png' (28 KB)
Download 'shot.png' (261 KB)
Preview of image 'scene.png'
Preview of image 'shot.png'
> How to use:
That's an outstanding support here :)
Tested it, and it works.
Tried the Hubble, the Voyager, and there they are.
Nice Idea to save all parts in different variables.
But have problems with this model (see pic):
https://science.nasa.gov/3d-resources/ingenuity-mars-helicopter/
Is it an error in the glb-file?
And is it possible to extract the textures also?
2 new ideas:
- save the pov-lines how to use the code in a docu-block in the upper part of
the file
- save the name of the original file also somewhere (have now many files in my
download-folder like "model (4).inc" and dont know whats in it.
ma
Download '20251004_00h16m11s_grim.png' (348 KB)
Preview of image '20251004_00h16m11s_grim.png'
It is very cumbersome and annoying to try out textures directly in the text file
with Povray.
You set something in the texure, render the image, change bump-values or colours
or something again, render by cmd-line, still don't look good, back into the
text file...
That's why I thought about a web interface that offers select boxes and sliders
for the different settings, re-renders at command, and displays the image.
I think that would be much faster and more relaxed.
If something similar already exists, just let me know the website.
ma
Thanks, we are pleased to help :)
No, the file is OK, you can check this yourself here:
https://threejs.org/editor/
The project in beta state now, so some issues are possible,
will fix it soon. Many thanks for testing and bug reports -
I am really need them.
Interesting, I guess yes, will try it little bit later.
Right now I am working on POV-Ray materials support.
> 2 new ideas:
> the file
Good idea, saved it to my TODO list.
Wishing well.
YB
> with Povray.
Yes, I know, but I did not see any online GUI anywhere.
I am thinking about something like this, but implementation could be
tricky. As far as I know, Blender supports POV-Ray and has a GUI, but I
don't know details, preferring C4D.
YB
> for the different settings, re-renders at command, and displays the image.Btw, last
year I did this experimental project for server-side
rendering, maybe it was the first step toward what you are dreaming
about ? :)
YB
