POV-Ray : Newsgroups : povray.binaries.utilities : Online files converter Server Time
11 Oct 2025 21:43:30 EDT (-0400)
  Online files converter (Message 36 to 45 of 95)
Subject: Re: Online files converter
Date: 30 Sep 2025 10:07:18
Message: <68dbe416$1@news.povray.org>
On 30/09/2025 15:04, Kenneth wrote:
> That is really a fabulous service, yesbird! I just used it to convert two
> binary-file STL models (from Thingiverse) that I have been wanting to see in
> POV-ray for a long time.
Many thanks, I am glad that you find it useful.
> Your site works beautifully, and the upload/download speeds for me are VERY
> fast. I am amazed at how quickly you wrote code to accomplish this task. Thank
> you!
The reason is a set of tools I am using: HTML5/JS/Three.js.
After a long time working with C++/Linux I feel like playing Lego toys
comparing to complicated real-world mechanics :).
> I know that you are busy with other things, but I have several small(?)
> suggestions:
This is very much in time. It will help me to make this service better,
thanks for detailed feedback, please share your ideas about possible
improvements and additional features. For example, I am thinking about
extending the list of materials and adding a reference grid(s).
> One of the models I uploaded (see my attached POV-ray render of your conversion)
> is a very high-triangle-count model, and very smooth when 3D-printed-- and it
> actually looked better on your webpage when I checked 'flat shading' there. As
> you can see here, the 'smooth triangles' of the converted mesh2 are causing the
> sharp edges to 'crinkle'...similar to what I saw when the model was 'smoothed'
> on your page.
> My suggestion would be to allow a *choice* of downloading the mesh2 model as
> 'smooth triangles' or as just flat un-smoothed ones. My guess is that there are
> plenty of STL models available that don't really need such smoothing, because of
> their high triangle count.
Agree with you and this is already works right "out of the box": just
select the "Flat shading" checkbox and _then_ download a model - you
will get exactly what you see :). The same approach works also for
"Vertex colors". I will write detailed help after some code polishing.
> My 2nd suggestion: Currently, your mesh2 downloads are named 'model' (as is the
> mesh2 itself.) They show up in my 'downloads' file...which, sadly, I don't
> immediately check or look at when I am busy with other things. So my second
> suggestion would be to *number* your converted files in some way, so that every
> file we convert has a unique number-- like model6374, similar to what
> Thingiverse does. The reason is that we could be uploading/downloading several
> models in quick succession...and new downloads could overwrite the previous ones
> if we are lazy :-O
Interesting idea, I will think about it. Implementation is trivial,
just need to be sure that this will be really convenient.
> Thanks again for taking the time to create your site.
Always welcome !
Btw, you mentioned 3D printing - what model do you have and what
software do you prefer ? Mine is CREALITY3D ENDER-3 Pro / Simplify3d.
> Over the last several days, I have been working on my own ascii-STL-to-mesh
> converter scheme, totally within POV-ray as SDL code (well, along with some
> 'manual/automated' editing of the STL file to get it into a form that POV-ray
> can #read.) But it's all accomplished within the program, no external editor
> required. Anyway, I finished it last night, and it works quite nicely. But THEN
> I saw that you had created your online converter! Which of course works better
> and faster than my DIY scheme. Mine only works with ascii files anyway.
> I think I will still post it though, for those hardy souls who like doing things
> themselves. ;-)
No doubt - publish it !
Someone can use your code as an example for similar projects.
Wishing well.
YB
Date: 30 Sep 2025 15:50:00
Message: <web.68dc33d1c9089336e83955656e066e29@news.povray.org>
> > if we are lazy :-O
> My browsers usually append a (1), (2), .. (n) to the filename automatically.
> Maybe you have similar in settings?
Ah, you're right, and I had forgotten; Firefox/Windows does that as well. I just
tested it again. (It has been a long time since I downloaded multiple copies of
the same file name.)
But uniquely-numbered downloads from yesbird would still be useful :-D
Date: 30 Sep 2025 16:00:00
Message: <web.68dc35a2c9089336e83955656e066e29@news.povray.org>
> select the "Flat shading" checkbox and _then_ download a model.
Oh, I didn't know! That's great-- and I am even MORE impressed that you already
implemented it. Thanks for the tip!
Your hard work is very much appreciated.
Date: 30 Sep 2025 19:27:08
Message: <68dc674c@news.povray.org>
I am very glad. Btw, I added a floor grid for better visual experience.
Please don't forget to share your renderings here ).
YB
Download 'floor.png' (126 KB)
Preview of image 'floor.png'
Date: 1 Oct 2025 17:45:00
Message: <web.68dda068c9089336730a79cb30225ff5@news.povray.org>
I just tried it with some models from NASA.
glb and stl, none worked for me.
https://science.nasa.gov/3d-resources/crab-nebula/
https://science.nasa.gov/3d-resources/hubble-space-telescope-a/
tried also cassini, DS1, EVA, and some others.
Chromium (Rasberry Pi) and Firefox.
Only this model showed something, unfortunately not more than a part of the
Antenna-Boom.
https://science.nasa.gov/3d-resources/viking-lander/
ma
Date: 1 Oct 2025 18:56:12
Message: <68ddb18c@news.povray.org>
Thanks for feedback, to fix GLB issue I need to add one more compression
feature.
'Crab Nebula (disc).stl' works fine for me (see attachment).  Can you
please press F12 and send me a content of 'Console' tab ?
YB
Download 'crab nebula (disc).png' (274 KB) Download 'scene.png' (17 KB)
Preview of image 'crab nebula (disc).png'
Preview of image 'scene.png'
Date: 1 Oct 2025 19:21:39
Message: <68ddb783@news.povray.org>
> feature.
'Crab Nebula.glb' works fine now ( see attachment), please try it again.
YB
Download 'scene_glb.png' (11 KB)
Preview of image 'scene_glb.png'
Date: 1 Oct 2025 20:23:43
Message: <68ddc60f$1@news.povray.org>
> Antenna-Boom.
The reason is multiple meshes, contained in this scene, but conversion
is possible only for one. Merging all of them  will produce complete
model.
YB
Date: 2 Oct 2025 03:15:00
Message: <web.68de259dc9089336730a79cb30225ff5@news.povray.org>
> > feature.
> YB
AsyncLoader.js:51 Error: THREE.GLTFLoader: No DRACOLoader instance provided.
    at new GLTFDracoMeshCompressionExtension (GLTFLoader.js:1922:10)
    at GLTFLoader.parse (GLTFLoader.js:400:37)
    at Object.onLoad (GLTFLoader.js:245:11)
    at three.module.js:44568:38
_onError @ GLTFLoader.js:225
AsyncLoader.js:37 Problem loading:
uploads/d91ecd2052b7fe17892df46e1a6d97a43a76a4f8/Crab Nebula.glb
Date: 2 Oct 2025 03:20:00
Message: <web.68de2716c9089336730a79cb30225ff5@news.povray.org>
> model.
> YB
handling of multiple meshes would be a nice feature :)
Without it I have to learn how to convert the files first.
Your Website and the GUI of all2mesh looks nice.
Have checked it out, also the other tools.
Maybe some words about them, small description what they are doing?
And who has created them?
Do you know an online-tool to create textures for Povray?
I've already thought about programming something like this myself.
Greetings from Cologne,
Ma
