POV-Ray : Newsgroups : povray.binaries.utilities : Online files converter Server Time
11 Oct 2025 21:42:10 EDT (-0400)
  Online files converter (Message 24 to 33 of 95)
Subject: Re: Online files converter
Date: 28 Sep 2025 20:37:25
Message: <68d9d4c5$1@news.povray.org>
On 29/09/2025 03:00, Bald Eagle wrote:
> Looks good.
> Got the teapot when the webpage loaded.
> Took maybe 30 sec to convert the ghost.
> (slick future feature would be to use a url, and convert from inside a zip.)
YES! I am glad that finally you win.
But 30 sec is toooo looong for such small model, I am getting result in
2-3 sec, but there is ocean between us :).
Possible solution: I can open github repository and you will be able to
install this service on more accessible server.
> Thank you, Sergei.
You are always welcome, now I am start thinking about spline
editor for POV-Ray, based on this example:
https://threejs.org/examples/webgl_geometry_spline_editor.html
YB
Date: 28 Sep 2025 21:30:00
Message: <web.68d9e010c90893361f9dae3025979125@news.povray.org>
Yes, I am certain that such a thing would be useful.
Ed Hynan wrote
https://web.mit.edu/povray_v3.7.0a/epspline.pdf
a while back,
and there was the PointWriter project
And someone had a spline workshop, IIRC.
Tor Olav Kristensen (TOK) has a lot of spline stuff on github
Jerome Grimbert (Le Forgeron) has his hgpov38 project that uses a wide variety
of splines
And I made a big list for jr of all the different spline types
So there's certainly a lot of things that could keep you busy  ;)
- BW
Date: 29 Sep 2025 07:10:18
Message: <68da691a$1@news.povray.org>
Many thanks for this info, I will get back to splines after converter
polishing. Btw, would you suggest the best way to inform the community
about its existence ?
YB
Date: 29 Sep 2025 08:15:00
Message: <web.68da7833c908933644a8a4be25979125@news.povray.org>
> polishing.
Of course.
It's always nice to have a sort of head-start, with some keywords and even code
to get things moving quickly.
What I would greatly suggest is that you not just leave it as a converter, but
add some small embellishments to make it a valuable learning tool.
It ought to be easy enough to make a small mesh and show how the normals are
calculated, how vector cross products allow the order of the vertices to
determine the direction of the normal, etc.
[X] Create an explanatory diagram as an .inc file
Then you can not only advertise it here on the forum, and elsewhere, but also
slip references to it in discussions on stackexchnge, stackoverflow, Wolfram,
and other places.  Make sure you have a didactic, academic graphic that will
attract computer science / graphics / gaming students to visit your app if they
come across it in a web search.  That way it has a lasting value completely
aside from JustAnotherFileConverter.
Make sure you put some prominent references to POV-Ray and the newsgroups in
your graphic. (I'd also suggest putting some standard POV-Ray header info in the
inc file, along with a reference to you & your web converter URL)
That way, if people find your project to be a useful learning tool in addition
to it being just a converter, they may be encouraged to try POV-Ray, and get
involved with many of the projects - including the ones you are working on, or
don't have time to work on.  And I have no problem with using 3js as the basis
for a new version of POV-Ray, so any CG tools developed in 3js are valuable as
well. (You know I draw my knowledge and inspirations from a wide range of
platforms and sources)
So - that's always where my mind is going when we talk about any project.  "How
do we attract people and bring them together to (re)build a thriving computer
graphics community"
- BW
Date: 29 Sep 2025 08:25:59
Message: <68da7ad7$1@news.povray.org>
Bill, thank you very much for this bundle of ideas, I will think about
them and follow your suggestions.
> graphics community"
Exactly, good luck with it. :)
YB
Date: 29 Sep 2025 16:35:37
Message: <68daed99$1@news.povray.org>
On 28/09/2025 01:27, yesbird wrote:
> Finally, after two sleepless nights I finished a web application that
> converts obj, fbx, glb, gltf, stl formats to mesh2:
> https://povlab.yesbird.online/all2pov
It is completed now: I implemented a progress bar and added two
additional metal materials for preview.
YB
Date: 30 Sep 2025 05:05:00
Message: <web.68db9d23c908933616086ed06830a892@news.povray.org>
> I tested it only on a limited number of files, so some issues
> (especially related to displaying a model) are possible, testing  now in
> progress. Please send any kind of feedback: bug reports, suggestions,
> requests to implement, etc.
> YB
This looks awesome !!!
But I get " 504 Gateway Timeout " from behind my corporate proxy.(for all of
your site by the way).
So trying on my phone, I get a display smaller than my screen. but appearing
functional.
Date: 30 Sep 2025 05:10:00
Message: <web.68db9dbbc908933616086ed06830a892@news.povray.org>
yesbird wrote:
> On 28/09/2025 15:42, Bald Eagle wrote:
> > You could also possibly have a labeled grid, and display the center of the
> > object in text.  Maybe have a checkbox "Center at origin".
> > OK, maybe since a lot of objects are things that sit on a surface, have a second
> > checkbox that centers the object, and has its ymin set at 0.
> This is the point for discussion: should converter change
> object's coordinates or just repack then into other format ?
> I guess, this is the editor's function.
> Maybe, it will be better just position the camera to look at object
> and set acceptable zoom ?
> In attachment: 'hand', loaded into C4D.
> YB
I think you should look at GIS packages (QGis/OpenSceneGraph...), and the way
geometries are coupled with a text based projection file... recording
coordinates, centering for treating and reapplying on exit. or leaving separate
file from option?
Date: 30 Sep 2025 07:12:21
Message: <68dbbb15$1@news.povray.org>
> file from option?
Thanks - this is an interesting idea, taking in account that I have
experience working with QGis and like it very much.
There is always a space for improvement :)
YB
Date: 30 Sep 2025 07:35:37
Message: <68dbc089$1@news.povray.org>
Thanks, to my pleasure ).
Sad times we are living in ...
> functional.
I didn't think about mobile platforms, working on design, so some
distortions are possible, but maybe this is better than nothing.)
At present the assumed resolution is HD 1920x1080, but I will try to
improve it.
YB
