On 29/09/2025 01:02, Bald Eagle wrote:
> I would say it depends on what the user wants.
I absolutely agree with all your statements, let's collect
user's opinions and then make decisions about further development.
The only question I have: how to inform the maximum number of 'povers'
about this service ?
YB
yesbird wrote:
> Looks like WebGl1 is insufficient for Three.js and it wants WebGL2.
> Did you tried it with Opera ?
Looks to be the same thing.
Tried enabling a thing in Brave to allow WebGL2, but that didn't work.
I'll give it a whirl in Edge since I already have the Win11 spyvirus on my
laptop.
- BW
> laptop.
Beg me pardon, but why not Chrome or Firefox ?
YB
> laptop.
Looks good.
Got the teapot when the webpage loaded.
Took maybe 30 sec to convert the ghost.
(slick future feature would be to use a url, and convert from inside a zip.)
mesh.inc autosaved to my downloads folder.
object is called "model"
Not centered at origin
No inside_vector defined
After finding my object with min_extent, translating and rotating
it seems to work fine.
Thank you, Sergei.
- BW
Download 'ghostmesh.png' (18 KB)
Preview of image 'ghostmesh.png'
Thou hast no need for begging for anything, least of all a pardon.
I simply don't have those installed on any of my machines.
I do have "LibreWolf", but many sites don't like the signature of that.
- BW
On 29/09/2025 03:00, Bald Eagle wrote:
> Looks good.
YES! I am glad that finally you win.
But 30 sec is toooo looong for such small model, I am getting result in
2-3 sec, but there is ocean between us :).
Possible solution: I can open github repository and you will be able to
install this service on more accessible server.
> Thank you, Sergei.
You are always welcome, now I am start thinking about spline
editor for POV-Ray, based on this example:
https://threejs.org/examples/webgl_geometry_spline_editor.html
YB
Yes, I am certain that such a thing would be useful.
Ed Hynan wrote
https://web.mit.edu/povray_v3.7.0a/epspline.pdf
a while back,
and there was the PointWriter project
And someone had a spline workshop, IIRC.
Tor Olav Kristensen (TOK) has a lot of spline stuff on github
Jerome Grimbert (Le Forgeron) has his hgpov38 project that uses a wide variety
of splines
And I made a big list for jr of all the different spline types
So there's certainly a lot of things that could keep you busy ;)
- BW
Many thanks for this info, I will get back to splines after converter
polishing. Btw, would you suggest the best way to inform the community
about its existence ?
YB
> polishing.
Of course.
It's always nice to have a sort of head-start, with some keywords and even code
to get things moving quickly.
What I would greatly suggest is that you not just leave it as a converter, but
add some small embellishments to make it a valuable learning tool.
It ought to be easy enough to make a small mesh and show how the normals are
calculated, how vector cross products allow the order of the vertices to
determine the direction of the normal, etc.
[X] Create an explanatory diagram as an .inc file
Then you can not only advertise it here on the forum, and elsewhere, but also
slip references to it in discussions on stackexchnge, stackoverflow, Wolfram,
and other places. Make sure you have a didactic, academic graphic that will
attract computer science / graphics / gaming students to visit your app if they
come across it in a web search. That way it has a lasting value completely
aside from JustAnotherFileConverter.
Make sure you put some prominent references to POV-Ray and the newsgroups in
your graphic. (I'd also suggest putting some standard POV-Ray header info in the
inc file, along with a reference to you & your web converter URL)
That way, if people find your project to be a useful learning tool in addition
to it being just a converter, they may be encouraged to try POV-Ray, and get
involved with many of the projects - including the ones you are working on, or
don't have time to work on. And I have no problem with using 3js as the basis
for a new version of POV-Ray, so any CG tools developed in 3js are valuable as
well. (You know I draw my knowledge and inspirations from a wide range of
platforms and sources)
So - that's always where my mind is going when we talk about any project. "How
do we attract people and bring them together to (re)build a thriving computer
graphics community"
- BW
Bill, thank you very much for this bundle of ideas, I will think about
them and follow your suggestions.
> graphics community"
Exactly, good luck with it. :)
YB
