POV-Ray : Newsgroups : povray.binaries.utilities : img2mesh geometry improved Server Time
4 Dec 2025 17:17:06 EST (-0500)
  img2mesh geometry improved (Message 1 to 3 of 3)
Subject: img2mesh geometry improved
Date: 22 Sep 2025 05:39:42
Message: <68d1195e@news.povray.org>
Greeting,
while fiddling with some old ideas I unintentionally managed to improve
some aspects of my img2mesh Python image to heightfield 3D mesh converter.
You can view the results at the top of img2mesh page, updates section:
https://dnyarri.github.io/img2mesh.html
and download either Python originals or compiled Win10 exe.
In view of recent discussion "I would like to ask the community: do
we really need it?"
I mean new version uses geometry switch based on source local contrast,
corresponding threshold control is added to program GUI but, obviously,
it doesn't give real-time preview of final rendering. In theory, I may
add something like ruby mask preview (like one in Photoshop) for local
contrast to GUI, but, considering my extremely poor programming skills
and bad memory, it would be quite time consuming. Surely, I was able to
make a preview for filtering (you may see it at the bottom of my POV‑Ray
Thread: Linen and Stitch at
https://dnyarri.github.io/povthread.html#averager
so I can do this, but it wasn't easy.
So, the question is: does anybody really need this img2mesh and stuff?
Ilyich the Toad
Subject: Re: img2mesh geometry improved
Date: 22 Sep 2025 13:45:00
Message: <web.68d18b10760e66756ddd22546cde94f1@news.povray.org>
hi,
Ilya Razmanov <ily### [at] gmailcom> wrote:
> Greeting,
> we really need it?"
interesting question, though not, perhaps, the correct one </grin>.  will think
about it more but "gut feeling" says yes.  not just because, in a real sense, it
is new/different, but there's also the "aspect" that as creator of XYZ you have
no control, and can have no real idea, what uses others have/will find for XYZ.
regards, jr.
Date: 23 Sep 2025 06:46:41
Message: <68d27a91$1@news.povray.org>
Congratulations, this is excellent work !
I guess this method will be demanded not only by POV-Ray community, may
be I will manage myself to rewrite it on Javascript to extent Three.js
library (asking your permission before :)).
YB
Date: 23 Sep 2025 07:55:00
Message: <web.68d28a38760e667517bac71e8ffb8ce3@news.povray.org>
> Greeting,
Interesting what you do with the sharp transitions.
Other method that could work in various cases:
1. First calculate the face normal, either by cross product of three edges or
Newell's method
Newell:
  for i in 0..<vertices.len:
    let curr = vertices[i]
    let next = vertices[(i + 1) mod vertices.len]
    normal.x += (curr.y - next.y) * (curr.z + next.z)
    normal.y += (curr.z - next.z) * (curr.x + next.x)
    normal.z += (curr.x - next.x) * (curr.y + next.y)
  return normalize(normal)
2. Now calulate the vertex normals, there several weighting types can be used,
based on properties of the adjacent polygons.
   Weighted by area, weighted by angle or just average the face normals as they
are.
Regarding usefulness, always. Users do crazy things :) It may also be useful if
you provide an export as arrays, so one can (ab)use the data in SDL.
ingo
Date: 23 Sep 2025 10:15:00
Message: <web.68d2ab3b760e66751398638025979125@news.povray.org>
> Newell's method
> Newell:
> are.
You're making me want to revisit one of my other small projects:
https://news.povray.org/web.655dee4084c692a31f9dae3025979125%40news.povray.org
Too much to do, too little time.
- BW
Date: 23 Sep 2025 13:48:48
Message: <68d2dd80$1@news.povray.org>
>> Greeting,
Oh, it's all pretty simple (remember that I started it for my own use,
and not a science project).
I was disappointed with the way POV-Ray treats bitmapped heighfield, and
decided to try some heighfiled to mesh conversion on my own. Initial
idea was simple: lets assume we have 2x2 pixel area of source image,
numbering pixels according to Soviet Army "snail" rule:
1 2
4 3
those values (brightness) we name v1 - v4.
Simplest way to make triangles would be two triangles, 1-2-4 and 2-3-4,
forming a square, folded along 2-4 diagonal. It works, but not too cool,
so instead of 2 triangle fold I tried 4 triangle pyramid, involving
interpolated point 0, having v0 = (v1 + v2 + v3 +v4) / 4. So four
triangles looked like 1-2-0, 2-3-0, 3-4-0 and 4-1-0. This looked
definitely better than POV-Ray heighfield; I also tried to compare it
with patches and found to be similar). However I don't like artifacts
like peaks it produces for cone gradients. But spontaneously I though
that fold structure above is a case of pyramid structure with v0 = (v2 +
v4) /2, so combining two geometries is only a matter of setting v0 to
average of either two or four pixels. So I did this; decision is based
on simple criterion:
# ↓ Switch between geometry №1 and №3.
#   Threshold set ad hoc and is subject to change
if abs(v1 - v3) > threshold or abs(v2 - v4) > threshold:
     # ↓ Geometry №1, better sharp diagonals handling
     if abs(v1 - v3) > abs(v2 - v4):
         v0 = (v2 + v4) / 2  # Fold along 2 - 4 diagonal
     else:
         v0 = (v1 + v3) / 2  # Fold along 1 - 3 diagonal
else:
     # ↓ Geometry №3, better for smooth areas
     v0 = (v1 + v2 + v3 + v4) / 4
Note that it includes two folding directions, 2-4 and 1-3, for / and \
diagonals.
So, now I have only one problem: choosing threshold. Surely I used
common sense (I have vast supplies of common sense, "hot' lozhkoy zhuy")
and added some experiments to it before setting defaults, but it's still
a matter to discuss.
As we are talking of source image areas like 2x2 pixels, I see no sense
in calculating normal and other wise and complicated stuff. I think I
can make decisions regarding local source contrast based on simple
arithmetics like difference and stuff.
Ilyich the Toad
Date: 23 Sep 2025 14:03:16
Message: <68d2e0e4$1@news.povray.org>
You are allowed to use it as long as you keep hailing the Toad all the
time. Oh, and bring me all your money you silly humans.
Seriously, I don't see anything special regarding my algorithm, just
some common sense, so surely use it at will if you find it useful.
In fact, there is a room for improvements: I use the fact that fold
geometry is just a particular case of pyramid one, and I use it with
"sharp" threshold-based "if" condition. Surely I may try some "smooth"
solution, with folds gradually turning into pyramids, for example,
linearly based on local contrast. The problem is, all this comes to "I
like the way it looks" criterion in the end, and I still don't have
precise mathematical definition for "look", not to mention "like".
Ilyich the Toad
Date: 23 Sep 2025 14:15:00
Message: <web.68d2e375760e66751398638025979125@news.povray.org>
To me, this seems similar to a convolution kernel.
I wonder if you could draw inspiration from that field and achieve some other
effects.  All of your other experiments have yielded really nice results, so I
can only imagine that you would develop some pretty spectacular stuff.
- bw
Date: 30 Sep 2025 06:25:00
Message: <web.68dbafdb760e667516086ed06830a892@news.povray.org>
> Greeting,
> we really need it?"
> Ilyich the Toad
Latest proposition for sharp transtion is very cool and even more "opinionated"
features like that are what give it most purpose !
I did not think of it that way before but if turned into a python library
without any other dependencies than those shipped in Blender (getting it more
easily "substitutable" to tkinter) , this would definitely be a good candidate
to integrate as an option for low res enhancement within the current POV@Ble
(blender's POV addon) heightfield primitive!
Date: 30 Sep 2025 11:01:44
Message: <68dbf0d8$1@news.povray.org>
This would require me learning Blender addons API. Currently my export
modules for img2mesh are a module already, but they are written to
receive source image data in the form I like, namely nested list. I find
this form both logical and suitable (my POV-Ray Mesh includes image
filtering module, and if you take a look at it, you'll see that this
image structure allowed me to write simple generalized filter for
arbitrary number of channels - it simply processes lists/vectors via map
regardless of their length). So my programs are rather modular, but in
the way I like. Others may have different ideas.
Ilyich the Toad
