POV-Ray : Newsgroups : povray.binaries.utilities : Modified Circle_Text() Server Time
30 Mar 2026 06:52:36 EDT (-0400)
  Modified Circle_Text() (Message 1 to 1 of 1)
Subject: Modified Circle_Text()
Date: 13 Nov 2004 13:34:05
Message: <4196539d@news.povray.org>
The way the default circle_text macro is currently written, it's
difficult to model text where the serifs are aligned to the y-axis and
the object bends as if it's wrapped around a vertical cylinder (with the
default macro, the text lays flat on the z-plane). So I
modified it by adding another parameter.
To use, write one more value at the end of the macro, specifiying the
vertical angle of the letters. -90 results in a "normal" alignment
(right side up),
90 makes it upside down. 0 gives the same result as the unmodified macro.
Just replace your default shapes.inc with the attached file.
~Mike
Download 'us-ascii' (29 KB)
