POV-Ray : Newsgroups : povray.binaries.utilities : povgui lost? Server Time
30 Mar 2026 10:13:35 EDT (-0400)
  povgui lost? (Message 1 to 6 of 6)
Subject: povgui lost?
Date: 11 Oct 2001 17:06:53
Message: <3bc609ed@news.povray.org>
sh*t!
i downloaded povgui, but the packet was damaged. and then my newsreader
cleaned all old articles... now povgui is gone and i can not download it
anymore. may someone post it again?
thank you.
Subject: Re: povgui lost?
Date: 11 Oct 2001 17:16:39
Message: <3BC60C38.8EABE5BA@aol.com>
marabou wrote:
> sh*t!
> thank you.
Absolutely - thanks for your interest. Let me know what you think. Note: you
will have to render field.pov with TGA output to get the height field in the
demo to run.
Download 'povgui15.zip' (131 KB)
Date: 11 Oct 2001 19:36:05
Message: <3bc62ce5@news.povray.org>
> you will have to render field.pov with TGA output to get the height field
> in the demo to run.
thank you for sending the code. but there seemed to be problems with your
zipper or the archive is damaged. i got the same mistakes with it like last
time when i thought the problems came by a crashed download: the file
<Insert> [27654 bytes] exists many times in the archive and it is empty,
also the file <POVGUI> [17704 bytes] is totally empty.
i did not find a file with extension <tcl>, is it right?
i am glad if you would have a look on it.
Date: 12 Oct 2001 06:55:56
Message: <3bc6cc3c@news.povray.org>
No problems at all here. Everything unzips correct. So did the last posted
archive.
BTW: There are better ways to get old messages, then asking for a repost of
177k, I think. This server saves all messages, so you only have to tell your
newsreader to get those old messages again.
Marc-Hendrik
Date: 12 Oct 2001 09:04:54
Message: <3bc6ea76@news.povray.org>
> in the demo to run.
i made several changes, because it seems to be a windows version.
and i do not have a 3.5 version of povray. so povgui stops because it does
not know where the macro <trace> is defined. it is a pity.
but thank you for your pain.
Date: 12 Oct 2001 10:50:00
Message: <3BC70326.A079509C@aol.com>
If you have MegaPOV 0.7, you might try the 1.4 version of POVGUI, which runs
under MegaPOV. It doesn't have all the features, but it does work. Check this
folder for a message called "POVGUI 1.4" to download. Or, you could upgrade to
3.5 <g>.
