POV-Ray : Newsgroups : povray.binaries.utilities : Cloth simulator version 0.3.0 Server Time
24 Jun 2026 00:19:00 EDT (-0400)
  Cloth simulator version 0.3.0 (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Cloth simulator version 0.3.0
Date: 23 Feb 2001 11:29:16
Message: <3A968FDD.E3892863@gmx.de>
>         With bugfixes, animation, a first stab at self intersection (untested, I
> ran into some unrelated bugs while testing it and had to fix them) and
> an height-field object (I'm not satisfied with it though and I'll
> probably remake it).
Windows version is on my site, still has the old stability problems,
sometimes it stops after a few seconds, the flag sample works though.
Date: 23 Feb 2001 13:24:00
Message: <3a96aac0@news.povray.org>
I can't get the windows version to work at all!
Mick
Date: 23 Feb 2001 14:48:17
Message: <3A96BE7E.311002AA@gmx.de>
What is the problem? (Error message?)
Date: 23 Feb 2001 21:45:35
Message: <3a97204f@news.povray.org>
Can we have some sample source code (flag.mpg--how'd you do that)?  This
proggy is great, but I want to do more than drap a tablecloth in my kitchen.
news:3A9### [at] inamecom...
> It's at the usual address:
> http://www.enst.fr/~jberger/cloth/cloth.html
> Jerome
> * Abandon the search for truth, * mailto:ber### [at] inamecom
> * Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 23 Feb 2001 22:35:03
Message: <3a972be7@news.povray.org>
"cadman" <NOS### [at] graffitinet> wrote in message
news:3a97204f@news.povray.org...
kitchen.
The flag.cl and associated files can be found in the source code on the
Cloth Simulator site.
Andy Cocker
listen to my music at:
www.mp3.com/lunarland
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
 - Steven Wright.
Date: 24 Feb 2001 11:37:00
Message: <3a97e32c$1@news.povray.org>
It parses for a bit(lots of disc thrashing) then stops, no error message.
I'm not sure it's working at all, attempting to run any switches gives the
error "parsing error on line 1"
Mick
Date: 24 Feb 2001 12:02:03
Message: <3A97E90A.E3BE52A2@gmx.de>
Even with -h and -V ?
Maybe check what Cygwin DLL version you are using.
Date: 14 Mar 2001 10:07:35
Message: <3aaf8937@news.povray.org>
I've got Cloth Simulator working on Windows 2000. (Thanks Chris H.).
Just a couple of queries....
1. When I try and run the example table cloth example with 20000 steps (-s
20000) I get the error:
NaN is not finite!
If I reduce the steps to 10000 then it runs okay. Is this a mistake in the
docs?
2. In the documentation it says that spheres are now supported. Has anyone
got example code of how to "drape" cloth over spheres (when I try I get the
error: NaN is not finite!)
3. I am trying to get a similar effect to the bottom right picture in the
examples at the top of the documentation (band of cloth draped across
serveral cylinders) but not getting very far? Jerome - do you have example
code to produce this picture?
4. What is the reason behind swapping the orientation(?) of z/y vertexes
between POV and Cloth.?
This looks like great bit of coding Jerome - just need a little help.
Thanks
Reuben
Date: 14 Mar 2001 13:04:28
Message: <3AAFB2AB.1070705@iname.com>
 > Just a couple of queries.... 1. When I try and run the example table
 >  cloth example with 20000 steps (-s 20000) I get the error: NaN is
 > not finite! If I reduce the steps to 10000 then it runs okay. Is
 > this a mistake in the docs?
	This is a known problem with the physics model. I'm trying to minimize
its effect, but I'll never be able to make it completely disappear. The
solution is to use a lower value for the step parameter (in the
global_settings section) and eventually compensate with more steps.
Unfortunately, this problem seems to occur more in the windows version.
 > anyone got example code of how to "drape" cloth over spheres (when
 > I try I get the error: NaN is not finite!)
 > in the examples at the top of the documentation (band of cloth
 > draped across serveral cylinders) but not getting very far? Jerome
 > - do you have example code to produce this picture?
	Sure I do :) I'll post it on friday.
 > vertexes between POV and Cloth.?
	Because of I still think more easily with the "standard" orientation whe
n
I need to do mathematics. Since I first started this program as part of
a project for the irtc, I wanted to do it fast and not loose time trying
to switch back and forth between the two systems. And then it was done
and I haven't gotten around to changing it (or at least make it
user-selectable)
		Jerome
Date: 16 Mar 2001 09:59:16
Message: <3AB22A43.4020904@iname.com>
	It's in p.b.s-f under the subject "Ribbon"
		Jerome
