POV-Ray : Newsgroups : povray.binaries.utilities : Cloth simulator version 0.3.0 Server Time
24 Jun 2026 00:19:00 EDT (-0400)
  Cloth simulator version 0.3.0 (Message 11 to 12 of 12)
Subject: Re: Cloth simulator version 0.3.0
Date: 14 Mar 2001 13:04:28
Message: <3AAFB2AB.1070705@iname.com>
Reuben Pearse wrote:
 > I've got Cloth Simulator working on Windows 2000. (Thanks Chris H.).
 > Just a couple of queries.... 1. When I try and run the example table
 >  cloth example with 20000 steps (-s 20000) I get the error: NaN is
 > not finite! If I reduce the steps to 10000 then it runs okay. Is
 > this a mistake in the docs?
	This is a known problem with the physics model. I'm trying to minimize
its effect, but I'll never be able to make it completely disappear. The
solution is to use a lower value for the step parameter (in the
global_settings section) and eventually compensate with more steps.
Unfortunately, this problem seems to occur more in the windows version.
 > 2. In the documentation it says that spheres are now supported. Has
 > anyone got example code of how to "drape" cloth over spheres (when
 > I try I get the error: NaN is not finite!)
 > 3. I am trying to get a similar effect to the bottom right picture
 > in the examples at the top of the documentation (band of cloth
 > draped across serveral cylinders) but not getting very far? Jerome
 > - do you have example code to produce this picture?
	Sure I do :) I'll post it on friday.
 > 4. What is the reason behind swapping the orientation(?) of z/y
 > vertexes between POV and Cloth.?
	Because of I still think more easily with the "standard" orientation whe
n
I need to do mathematics. Since I first started this program as part of
a project for the irtc, I wanted to do it fast and not loose time trying
to switch back and forth between the two systems. And then it was done
and I haven't gotten around to changing it (or at least make it
user-selectable)
		Jerome
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 16 Mar 2001 09:59:16
Message: <3AB22A43.4020904@iname.com>
	It's in p.b.s-f under the subject "Ribbon"
		Jerome
