POV-Ray : Newsgroups : povray.binaries.utilities : Announce: 3DWin 3.4 , a 3D file format converter + OpenGL Viewer + Import Plugin for Moray Server Time
31 Mar 2026 06:40:21 EDT (-0400)
  Announce: 3DWin 3.4 , a 3D file format converter + OpenGL Viewer + Import Plugin for Moray (Message 1 to 2 of 2)
Subject: Announce: 3DWin 3.4 , a 3D file format converter + OpenGL Viewer + Import Plugin for Moray
Date: 28 Mar 1999 01:38:56
Message: <36FDCECD.EB93BC60@ibm.net>
This program is a small utility to view and convert 3D
files to a number of other 3D formats. It can generate
smooth triangles for those formats  that support it,
allowing you to specify the angle under which the
faces should be smoothed. Additional each mesh could
be sized and unified (correcting bad face normals).
3DWin 3.4 is available at
 http://www.stmuc.com/thbaier
Whats new:
 - Import Plugin for Moray
 - SoftFX (*.sce) import/export plugin
 - Bug fixes
   Import:
    Generic ASCII format (*.raw)
    3dStudio (*.3ds, *.prj)
    Imagine (*.obj, *.iob)
    Lightwave (*.lwo, *.lws)
 Autodesk (*.dxf)
 POV-Ray (*.pob)
 WaveFront (*.obj)
 Direct X (*.x)
 Soft FX (*.sce)
   Export:
    3dStudio (*.3ds, *.asc)
    Lightwave (*.lws, *.lwo)
    Autodesk (*.dxf)
    RenderWare (*.rwx)
    VRML 1.0 (*.wrl)
    HighLight (*.obt)
    Direct X format for Microsoft (*.x)
    Real 3D (*.rpl, *.obj)
    POV-Ray and Moray (*.inc, *.udo)
    Polray and Moray (*.inc, *.udo)
 WaveFront (*.obj)
 OpenGL (*.C)
 SoftFX (*.sce)
Subject: Re: Announce: 3DWin 3.4 , a 3D file format converter + OpenGL Viewer + Import Plugin for Moray
Date: 28 Mar 1999 13:49:18
Message: <36FE798B.A33F5C0C@mninter.net>
Can you make just the plugin downloadable- I don't want to take the time
for 2.8 megs when I already have 80% of the stuff in the ZIP file
anyway...thanks!
Thomas Baier wrote:
> Hi,
> Whats new:
>  - Bug fixes
>    Import:
>  Autodesk (*.dxf)
>  POV-Ray (*.pob)
>  WaveFront (*.obj)
>  Direct X (*.x)
>  Soft FX (*.sce)
>    Export:
>     Autodesk (*.dxf)
>     RenderWare (*.rwx)
>     VRML 1.0 (*.wrl)
>     HighLight (*.obt)
>  WaveFront (*.obj)
>  OpenGL (*.C)
>  SoftFX (*.sce)
Only I can prevent narcissism!
