POV-Ray : Newsgroups : povray.binaries.utilities : Announce: 3DWin 3.3 , a 3D file format converter + OpenGL Viewer Server Time
31 Mar 2026 06:36:04 EDT (-0400)
  Announce: 3DWin 3.3 , a 3D file format converter + OpenGL Viewer (Message 1 to 1 of 1)
Subject: Announce: 3DWin 3.3 , a 3D file format converter + OpenGL Viewer
Date: 5 Mar 1999 01:23:52
Message: <36DF78FB.1256DC4A@ibm.net>
This program is a small utility to view and convert 3D
files to a number of other 3D formats. It can generate
smooth triangles for those formats  that support it,
allowing you to specify the angle under which the
faces should be smoothed. Additional each mesh could
be sized and unified (correcting bad face normals).
3DWin 3.3 is available at
 http://www.stmuc.com/thbaier/homepage.htm
Whats new:
 - LWS import
 - rewritten DXF import
 - Direct x Import
 - Bug Fixed in Axis swapping
 - Bug fixes
   Import:
    Generic ASCII format (*.raw)
    3dStudio (*.3ds, *.prj)
    Imagine (*.obj, *.iob)
    Lightwave (*.lwo, *.lws)
 Autodesk (*.dxf)
 POV-Ray (*.pob)
 WaveFront (*.obj)
 Direct X (*.x)
   Export:
    3dStudio (*.3ds, *.asc)
    Lightwave (*.lws, *.lwo)
    Autodesk (*.dxf)
    RenderWare (*.rwx)
    VRML 1.0 (*.wrl)
    HighLight (*.obt)
    Direct X format for Microsoft (*.x)
    Real 3D (*.rpl, *.obj)
    POV-Ray and Moray (*.inc, *.udo)
    Polray and Moray (*.inc, *.udo)
 WaveFront (*.obj)
 OpenGL (*.C)
