POV-Ray : Newsgroups : povray.binaries.utilities : TrueType patch! Server Time
12 Oct 2025 09:39:22 EDT (-0400)
  TrueType patch! (Message 1 to 10 of 15)
Subject: TrueType patch!
Date: 9 Dec 1997 22:11:47
Message: <348E0873.C5A421B1@cs.byu.edu>
Attached is a simple hack of the truetype.c file that makes text objects
be centered about the x-origin.  Could be useful for those tricky text
manipulations? :)  Perhaps if someone has time they could add a pov
"built-in" function to find the length of a string, so the users can
play with these things more...who knows...if i can find the time i may
do it myself! :)
Comments, criticisms, etc. are always welcome.  Just be nice... :)
- Jamis Buck
buc### [at] csbyuedu
http://students.cs.byu.edu/~buck
Download 'truetype.c.txt' (97 KB)
Subject: Re: TrueType patch!
Date: 9 Dec 1997 23:18:09
Message: <348e2604.0@news.povray.org>
Wonderful!  I have one suggestion.  It seems like pov doesn't generally
return information about an object, rather it gives you an object you know
information about.  For example, when you use height fields, pov maps the
height field to a 1x1x1 unit cube, from which it can be rotated, scaled, or
whatever.  It doesn't create a height field which is 640 units across and
480 units deep, and who knows how high, and then supply vectors giving the
dimensions.  The text object is the only one (to my knowledge) which does
not come prefit to a 1x1x1 cube, or require vectors to specify a size.  I
haven't looked at the code, so I don't know how difficult it would be, but
it seems to me that the text object would best be kept in the tradition of
other pov objects and automatically created in a 1x1x1 cube.  Unfortunately,
this kind of a change would violate backwards compatiblity.  My
recommendation is to add optional bounding vectors to the syntax of the text
object.  Similar to the syntax of a box, but optional.  That would allow for
backwards compatibility.  I'd be curious to hear any feedback about this
idea, both from a usability standpoint and programmability.
Ken
Jamis Buck wrote in message <348E0873.C5A421B1@cs.byu.edu>...
>do it myself! :)
>- Jamis Buck
Date: 10 Dec 1997 10:57:23
Message: <348EBBE3.6008@cougarnet.byu.edu>
I've thought about your suggestion, however, I think, at least from a
usability standpoint, there may be a better way to do it than to map
a text object to a 1x1x1 cube.  If the text was mapped to such a cube,
how would you know how much to scale it to make it look right?  You're
just back to trial and error, much like manipulating text right now.
Rather, I'm working on two new "built-in" functions, getlength and
getheight.  Both take a text string, a font name, and an offset (same
as a text object) and return (respectively) the length and height of
a text object of the given specs.  Doing this would allow users to
more easily manipulate a text object by doing simple math to center it,
resize it, etc.  With this information, one could even scale the text
to fit into a 1x1x1 cube, if one wanted.
So, that's what's happening right now.  I've almost got it...give me
another
week or so. :)  If anyone is interested in this, let me know and I'll
post
the altered source files to this group.
Ciao!
- Jamis Buck
> Ken
> >do it myself! :)
> >- Jamis Buck
Date: 10 Dec 1997 18:42:14
Message: <348F28D6.61CDA910@bigfoot.com>
<HTML>
Tarasine Short wrote:
<BLOCKQUOTE TYPE=CITE>So, that's what's happening right now.  I've
<BR>another
<BR>week or so. :)  If anyone is interested in this, let me know and
I'll
<BR>post
<BR>the altered source files to this group.</BLOCKQUOTE>
Yes please, that would be more than just usefull,
<BR>Cheers,
<BR>Al.
<P>=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
<BR>=-=-=-=-= ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
<BR>Pour me répondre, veuillez enlever les deux moins de mon adresse.
<BR>To answer me, please take out both minus signs from my address.
<BR> </HTML>
Date: 16 Dec 1997 09:01:39
Message: <349689C3.45B3@cyberstation.fr>
I totally agree.
Denis Olivier,
http://www.povlab.org, 3D modeller for POV-Ray 3.0
__________________________________________________________________
Image ?   http://www.povlab.org/cyber.asp?url=download/cuisine.jpg
Photo portfolio    http://www.povlab.org/cyber.asp?url=photos.html
Date: 16 Dec 1997 19:06:16
Message: <3497188a.0@news.povray.org>
Denis Olivier wrote in message <349### [at] cyberstationfr>...
but
of
>I totally agree.
Well.. You will then either be faced with "squashed" text, or really tiny
text, for longer strings.
Twyst================================
EFnet and NewNet #povray Channel Operator
Website: http://twyst.home.ml.org
E-Mail: twy### [at] v-wavecom
Date: 4 Jan 1998 15:15:29
Message: <34affcad.0@news.povray.org>
That's the same thing that happens with a height field in pov, but one you
get your squished object, you know exactly how it is squished, and can scale
it.
Ken
Twyst wrote in message <3497188a.0@news.povray.org>...
I
>but
>of
>>I totally agree.
Date: 18 Dec 1997 12:56:12
Message: <349963BC.E19802C2@ecs.soton.ac.uk-NOSPAM>
> I totally agree.
Nice idea, but it be just as awkward scaling it from a 1 cube to 'true'
proportions as it is to take the current text and squash it into a cube.
What would be useful would be a function to return the extremes of a
given object, allowing you to scale/translate it accurately according to
the actual dimensions of the object, rather than by trial and error.
Dylan
Date: 23 Dec 1997 23:12:30
Message: <34a28b0f.180308021@news.povray.org>
On Thu, 18 Dec 1997 17:56:12 +0000, Dylan Beattie
>> I totally agree.
I knew I had seen this posted somewhere; that's why I went and wrote
it.  I just couldn't find it back when I needed it.
Ahem.  For all those who agree with Mr. Beattie, your prayers are
answered.  You can find just the patch you need over in
povray.binaries.utilities or on my web page at
http://www2.fwi.com/~parkerr/traces.html
A C compiler and POV sources are required. I'll make a Win32 compiled
version available if there's enough interest (in email, please.)
Date: 23 Dec 1997 23:14:49
Message: <34a38bee.180531021@news.povray.org>
On Wed, 24 Dec 1997 04:12:30 GMT, par### [at] mailfwicom (Ronald L.
D'oh!  This _is_ povray.binaries.utilities.  Must get sleep.  Or
caffeine.
Mmmm... Caffeine....
