POV-Ray : Newsgroups : povray.binaries.tutorials : Check(er) Your Gamma Server Time
15 Apr 2026 19:26:50 EDT (-0400)
  Check(er) Your Gamma (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Check(er) Your Gamma
Date: 4 Nov 2009 23:14:54
Message: <4af2513e$1@news.povray.org>
On 11/4/2009 9:00 AM, clipka wrote:
> SharkD schrieb:
>> On 11/3/2009 11:27 PM, clipka wrote:
>>> Forgot to attach the image... here it is.
>> I see alternating gray squares. Should I kill myself now?
> I wouldn't go as far as that ;-)
> It's just that if you share your rendered images and/or scenes (or
> include files that do anything with color or brightness), other people
> will not get what you see. (Unless their system, too, happens to be
> mis-calibrated in the same manner :-))
The instructions for adjusting your display settings are already in the
docs, aren't they?
Mike
Date: 4 Nov 2009 23:58:17
Message: <4af25b69$1@news.povray.org>
> docs, aren't they?
If you're referring to setting up POV-Ray, then yes: The POV-Ray 3.6
instructions how to identify the proper Display_Gamma setting for your
system are still valid for 3.7.
If you're referring to setting up your image viewer / operating system /
  graphics driver / display hardware, you will have to check out the
respective manuals and/or them interwebs.
Usually your graphics card will have come with /some/ tool to check and
adjust your display gamma to whatever the operating system typically
expects, and most image viewers will rely on the operating system and
drivers for converting from the OS' standard gamma to the display
hardware gamma.
On a properly calibrated Windows PC, following the instructions to set
up your Display_Gamma should usually give you a setting of 2.2.
Date: 5 Nov 2009 06:30:01
Message: <web.4af2b6982d58a2835b81d0ec0@news.povray.org>
> You know your gamma settings are wrong if...
> ... you see a chrome sphere on a /checkered/ plane (even if you squint
> your eyes or look from a distance) in this image/scene.
> Ideally, the plane should appear in a featureless uniform grey (except
> for some moiree effects near the horizon and maybe in the reflection).
> If instead it appears to show squares of alternating shades of grey,
> something's bogus:
> (A) If you see checkering in the attached image file, then your image
> viewing software / operating system / graphics drivers / display
> hardware is poorly calibrated, and you should fix it before proceeding.
> (B) If (after fixing (A)) you see checkering in the preview window
> and/or the output file when rendering the scene file below, then your
> Display_Gamma (POV-Ray 3.6 and 3.7) and/or File_Gamma setting (POV-Ray
> 3.7 only), respectively, is wrong.
Well that produces a broken file for me if I choose to output a PNG file (i.e.
the gray value isn't half the white value). HDR output works though (as I assume
it's in linear space).
Cheers,
Edouard.
Date: 5 Nov 2009 10:46:45
Message: <4af2f365$1@news.povray.org>
Careful!
How did you /check/ that the gray value isn't "half the white value"?
If you squint your eyes to "blur" the black-and-white-striped squares,
and it then /appears/ to have the same brightness as the gray value,
then that gray value /is/ half as bright as the white.
Note that Photoshop lies to you about brightness (and so do your eyes).
Photoshop also uses physically wrong math when blurring images (at least
the old version I own does).
The /physical/ blurring by squinting your eyes, however, does indeed
comprise a physically correct "computation" of (black+white)/2 (taking a
few steps back may do the same job, and some people may just need to
take off their glasses), which obviously gives you a grey of /truly/
half the white value (*), which you can then visually compare to the
grey of /allegedly/ half the white value.
(* provided you have set your display's black point properly)
Date: 5 Nov 2009 16:15:01
Message: <web.4af33fb22d58a2835b81d0ec0@news.povray.org>
> Careful!
I can see it's displayed correctly. That's great. But you've taken the decision
that the file should be output with that display gamma baked in, and that's not
something that's desirable under all circumstances (like, for example, any
manipulation of the image afterwards).
No - Photoshop is doing a sensible thing, and that's to work in linear space
(exactly the same way that POV does). Photoshop is a production tool, and having
gamma applied half way through your workflow will just screw everything up.
If you assign a linear profile to the image (which you started to be able to do
in Photoshop 6), then Photoshop not only displayed the image correctly, but all
operations (like blurring it) also work exactly as you would want. I've attached
an image with a linear profile and one half blurred as an example.
Scaling the image also fails if there isn't a linear profile attached, and lots
of users here like to scale their final images down and don't really consider
that post-processing. Baked-in gamma makes that work incorrectly.
I'm arguing that for a digital artist who is using POV as part of their
workflow, having tools like Photoshop's blur give identical "output" to what you
see when you do the "squint" method, is a good thing.
I'm sure lots of people will be happy to bake the gamma into their file if they
are producing "final" images with POV, and not intending to post-process them in
any way (as long as they know scaling the image is then a no-no). But there are
plenty of others who use POV in a workflow that includes scaling and other post
processing, and we would be better suited with having linear ICC profiles
attached to the images. There is no "right" way, it all depends on how the user
is intending to use the image.
(Well, once ICC support is universal, then I would argue that a linear image
with the correct ICC profile is "right". We're not that far from that are we? On
my Mac, the OS, the browser, and image preview app, and the pro software like
Photoshop all get a linear ICC profiled file right every time...)
Cheers,
Edouard.
Download 'gamma-test-linear.png' (136 KB)
Preview of image 'gamma-test-linear.png'
Date: 5 Nov 2009 18:43:48
Message: <4af36334@news.povray.org>
No, this is absolutely the proper way to do it with PNG image files, as
per the PNG file specification.
No, that's exactly the problem: Photoshop is /not/ working in linear
space - it happens to work in /whatever/ space the image happens to be
encoded in.
As linear encoding gives a great deal of precision loss with
low-brightness values (at the benefit of some precision gain with
high-brightness values, where it's not really needed), thereby leading
to color banding in dark areas, linear encoding is /not/ suited for
8-bit color depth images.
Sure it is; however, color banding is a bad thing, and therefore 8-bit
linear encoded PNG is /not/ an option either.
Feel free to use "File_Gamma=1.0" on the output file, which does exactly
what you demand - except that it doesn't attach an ICC profile, but
"only" a gAMA chunk, because an ICC profile would inevitably have to be
a lie (POV-Ray is presently gamma- but not color space-aware). It's a
shame that Photoshop 6.0 fails to support the gAMA chunk, but that's not
POV-Ray's fault. And you can actually work around the problem by
manually assigning your favorite linear ICC profile to the image /after/
you have loaded it into Photoshop.
And don't complain about any color banding you may observe: You're
asking for it.
(BTW, to scale a gamma-encoded image without messing up the colors, I
can highly recommend IC. It does properly convert the image to linear
color space before resampling.)
Date: 5 Nov 2009 21:53:52
Message: <4af38fc0$1@news.povray.org>
> encoded in.
I thought that Photoshop always worked in LAB space?
Mike
Date: 5 Nov 2009 22:04:49
Message: <4af39251$1@news.povray.org>
The docs say, "Now, lower the contrast until the alternating white and
black bars on the left edge of each column are equal in width." What do
they mean?? Which width am I measuring?
Mike
Date: 6 Nov 2009 00:50:00
Message: <4af3b908$1@news.povray.org>
Um... I must confess that it's been a while since I last read that
section of the docs.
I'd recommend to just skip the brightness and contrast stuff (you should
have done that already when calibrating the display), and just do the
eyes-squinting part and following.
Date: 6 Nov 2009 03:45:11
Message: <4af3e217$1@news.povray.org>
A quick note about Photoshop and it's PNG support:
I'm using Photoshop since version 4.0 and currently CS3 (still not sure
about updating to CS4) and every version had broken PNG support in one
way or another. Usually the gamma and sRGB chunk was ignored, some
version did completely mess up 16 bps images and CS3 writes colorimetric
chunks (color primaries and whitepoint) but 'forgets' to add the gamma
chunk (and it claims when saving to PNG that this file format does not
support any metadata - a plain lie because PNG even supports XMP, the
way that is favored by Adobe itself for storing metadata).
Given the long time and that PNG is a quite simple format it seems not
that far fetched that PNG support is broken deliberately - as some
people claim - but I fail to see the reason behind it.
Thanks for the advertising ;)
-Ive
