For a try, I have 'converted' the POV documentation into a new form
which I find more readable.
Then again, this is just a beginning, and I have started with the part
which is the hardest to me : Interior and media.
It is not finished yet, but I'd like some feedback to know if it might
be useful to some of you and what improvements can be added.
It works best with Acrobat Reader 4.0 (the one with indexes on the left)
Fabien
Download 'interior.pdf' (119 KB)
In the ior section you might mention something about negative ior values after
you experiment with them.
Bye
Pabs
I'll mention it in the next version.
If I am right, negative ior values give a kind of glow. I definitely have to try
this one again.
Thanks for the comment.
> Bye
> Pabs
It looks good for a first try, but i personally don't find it that easy to
read :-)
Some things that i find very good in the official docu and that are
missing in your version:
- fixed width font for code parts
- keywords highlighted in the main text
- cross links in the text
i also miss the complete syntax description like:
INTERIOR:
interior { [INTERIOR_IDENTIFIER] [INTERIOR_ITEMS...] }
INTERIOR_ITEM:
ior Value | caustics Value |
fade_distance Distance | fade_power Power
MEDIA...
Of course these are only my personal preferences.
Christoph Hormann <chr### [at] gmxde>
> read :-)
Could you explain what you mean ?
I'll give the dealt-with keywords a different color from the rest of the
text.
Red should stand out.
That's something I'll add when it is finished.
> INTERIOR:
> INTERIOR_ITEM:
> MEDIA...
That's precisely the point. For a beginner, the complete syntax is
rather
obscure. You don't know what is inside what and what keywords are
allowed.
ie : for the INTERIOR_ITEMS, you have to refer to the INTERIOR_ITEM
below. And if you want to add some media, you have to follow your way
down to the MEDIA_ITEM.
I like the 'tree' shown in the index of Acrobat. It displays the
'parents' and 'children' links : You have to use 'interior' first to be
allowed to use 'media' in an object.
But then again these statements are mine and mine only.
By the way, this is not meant to replace the official documentation, but
merely an alternative.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
It's very common to do code parts in a non proportional font for better
readability.
Maybe you should consider making it more different from the official docu,
which is mainly designed for reference (apart from the 'beginning
tutorial' section)
On Thu, 16 Nov 2000 14:16:00 +0100, Fabien HENON wrote:
>Il s'agit d'un message multivolet au format MIME.
>--------------DB2B8FB4AEE0A511EF40ABED
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
Things I like:
* Different colors for text, code, default values, etc.
* Sans serif font for text (better for reading on screen, though I
prefer serifed fonts on paper).
* The open parentheses which indicates whether the keyword opens a
block.
Things I don't like:
* Text is too wide. Keep it to about 2/3 of the page.
* Same font for text and examples. I'd prefer examples to be set in a
fixed-width font (but not Courier, if possible), but at least it
should be different from text so that you can use the same font in
the text for short code snippets (alternatively you could use the
same color).
* The layout is strange. E.g., on p. 7 the example looks like:
interior {
media {
absorption rgb <0.4,0.9,0.7> } }
but it should be either on one line or look like:
interior {
media {
i.e. consistend indentation and closing parethesis below
corresponding keyword.
On p. 9 there are alernatively short and long lines!
* Missing syntax.
Things I'm not sure about:
* The yellowish background. It's quite nice on screen, but might cause
problems with printing (poor contrast, slow printing, high toner
usage). Most people seem to prefer to print long PDF files.
| | | hjp### [at] wsracat | -- Lutz Donnerhacke in dasr.
__/ | http://www.hjp.at/ |
