POV-Ray : Newsgroups : povray.binaries.tutorials : Help: Povray 3.1 new atmosphere stuff Server Time
15 Apr 2026 15:49:20 EDT (-0400)
  Help: Povray 3.1 new atmosphere stuff (Message 1 to 4 of 4)
Subject: Help: Povray 3.1 new atmosphere stuff
Date: 22 Nov 1998 14:09:38
Message: <36586112.2EBF@Stic.nEt>
Before Pov-Ray 3.1 came out, I think I had finally perfected the use of
atmospheric effects, then 3.l came out...heh. The problem I am having is
that the povuser.txt file doesn't have sufficient informatino on using
the new atmospheric effects. I ended up just droping it in a scene I was
working on, and it ended up working out for the better.
BUT, just so I know, how do I set an atmospheric effect to show a rainy
haze that only really shows up when light hits it (I was trying to get
spotlight beams to show up). I tried doing it, but I got a lot of
distortion and grainy stuff.. I thought about using clear boxes and
filling them with an atmosphere, but then I would also have to simulate
fog...argh! :)
Any help would be apreciated. If you could direct me toward an example,
or a documented source, that'd be just fine by me! :)
Also, any ideas of when Pov-Ray 3.1a will be comming out in Linux?
Subject: Re: Help: Povray 3.1 new atmosphere stuff
Date: 22 Nov 1998 14:19:56
Message: <3658635A.8DCDDD90@pacbell.net>
A short tutorial on media can be found at:
http://members.xoom.com/POVRAY3/media1.html
I don't know if it will help but it can't hurt.
I'm not sure about the official release of v3.1 for linux but
there has been an unofficial release or two. There was an
announcement on povray.general about it sometime shortly after
the official windows release came out. I believe the posters
name was Glen Berry and had the url. Twist's site might also
have a copy of it laying around. For that try:
http://www.twysted.net
Ken Tyler
Download 'us-ascii' (1 KB)
Date: 22 Nov 1998 14:39:03
Message: <365867FA.6959@Stic.nEt>
Wow that was quick :) Thanks for the help! ONE more thing, if you can
help me (I forgot to mention this after I posted it). the Pov-Ray DOC
(thank God for it) mentions about phasing pigments and such. However,
I'm having a problem doing it. I've done it before, but it wasn't fast
enough, so I upped the clock value:
sphere{
 <0, 0, 0>
 15
 pigment{
  bozo
  color_map{
  [0 rgb <1, 1, 1>]
  [1 rgb <0, 0, 0>]
 phase (clock*4)
but the AVI didn't show much. What I am wondienrg is how to properly
achive something like a realistic water texture (using a pigment and
*NOT* normal, as the reflection of objects goes to crap) that
ripples....
Thanks again for your help, hope I'm not being too annoying :)
Tim Soderstrom
> Ken Tyler
Date: 23 Nov 1998 10:04:53
Message: <365A1438.9887CDF0@aol.com>
Phase alone doesn't do a very good job of simulating water in my opinion.
You'll get better results by averaging patterns and moving them in
different directions.  You can include phase with the averaged patterns.
You really should use normals for creating your water surface.  The reason
it looks bad is that the official POV doesn't take angle into account for
calculating reflection.  You will get much better results using Mike
Paul's wyzPOV, which you can get at http://twysted.net.  It's also
included in the superpatch, minus the total internal reflection ( the part
that makes prisms act as a mirror).
Some pattern suggestions:  Try a gradient pattern for getting the look of
waves on the shoreline. Bumps looks good for farther out waves.  Try the
bumps traveling a little along the y axis too to get more variation to the
waves.
> sphere{
>  <0, 0, 0>
>  15
>  pigment{
>   bozo
>   color_map{
>   [0 rgb <1, 1, 1>]
>   [1 rgb <0, 0, 0>]
>  phase (clock*4)
> ripples....
> Tim Soderstrom
