POV-Ray : Newsgroups : povray.binaries.scene-files : Fade in a complex mesh Server Time
9 Dec 2025 22:05:55 EST (-0500)
  Fade in a complex mesh (Message 1 to 2 of 2)
Subject: Fade in a complex mesh
Date: 27 Oct 2016 19:40:01
Message: <web.58128fbe543e276ef0b3ab370@news.povray.org>
Any idea where I'm going wrong with this fade in? I want the CGL_band to be
transparent then fade in gradually with each animated shot. Ive got it to fade
to the gray un-textured solid, or Ive got it to fade into the texture from a
black silhouette but cant figure out how to fade in the whole thing from
transparent to fully visible...
Here is the code and the "CGL_solid.inc" is attached
#declare Sandy = color rgbt <1, .9, .35>;
#declare Transmit = .8;
#declare CM_Sandstone =
colour_map{
  [0.3 rgbt <1, 1, 1, 1.2*Transmit*(clock)>]
  [0.4 rgbt <1, 0, 0, Transmit*(clock)>]
  [0.41 rgbt <0.5, 0.3, 0.1, .5*Transmit*(clock)>]
  [0.42 rgbt <1, 0, 0, .75*Transmit*(clock)>]
  [0.6 rgbt <1, 0.5, 0, Transmit*(clock)>]
  [0.7 rgbt <1, 1, 1, .5*Transmit*(clock)>]
#declare FSandstone =
finish{
  diffuse 0.35 ambient 0.05
#declare TSandstone =
texture{
  pigment {Sandy
  turbulence 0.99}
  finish{FSandstone}
  normal {granite 5 scale 500}
#declare TStain = texture{
  pigment{
    //agate
    gradient <.3, 2, .1>//2
    turbulence 0.15
    colour_map{CM_Sandstone}
    scale 1000
  finish{FSandstone}
#declare TSandstone1 =
texture{TSandstone}
texture{TStain}
//               Include the solid from an external file
#include "CGL_solid.inc"
object {CGLband
        texture {TSandstone1}
        translate <-723750,-422.035,-9092750>}
Download 'cgl_solid.inc.txt' (99 KB)
Subject: Re: Fade in a complex mesh
Date: 27 Oct 2016 20:04:04
Message: <581295f4$1@news.povray.org>
> Hi,
> colour_map{
You want everything to have transmit 1 when clock reatch the value of 1.
In your actual code, this can NEVER appen. At most, it tops at 0.96 for
the first entry of your colour_map, and as low as 0.4 in the worst case.
0.9, 0.35, 0>
You need your transmit to go from zero to one, or from one to zero.
This may work beter for a fade out:
colour_map{
   [0.3 rgbt <1, 1, 1, clock>]
   [0.4 rgbt <1, 0, 0, clock>]
   [0.41 rgbt <0.5, 0.3, 0.1, clock>]
   [0.42 rgbt <1, 0, 0, clock>]
   [0.6 rgbt <1, 0.5, 0, clock>]
   [0.7 rgbt <1, 1, 1, clock>]
For a fade in, try this:
colour_map{
   [0.3 rgbt <1, 1, 1, 1-clock>]
   [0.4 rgbt <1, 0, 0, 1-clock>]
   [0.41 rgbt <0.5, 0.3, 0.1, 1-clock>]
   [0.42 rgbt <1, 0, 0, 1-clock>]
   [0.6 rgbt <1, 0.5, 0, 1-clock>]
   [0.7 rgbt <1, 1, 1, 1-clock>]
If any texture need to have any transmiting transparency when fully
visible, you need to restrict the range of your transmit accordingly.
Like this:
rgbt<1, 1, 1, 0.5+ 0.5*Transmit*clock>
If you have a filtering pigment, the filter need to drop to zero as the
transmit reatch one.
Sample:
rgbft<1, 0.5, 0.12, 1*(1-clock), clock>
This is the only case where you need the parantesis.
