POV-Ray : Newsgroups : povray.binaries.scene-files : test blob media for potential pattern Server Time
8 May 2024 14:22:37 EDT (-0400)
  test blob media for potential pattern (Message 1 to 3 of 3)
Subject: test blob media for potential pattern
Date: 13 Oct 2016 16:40:01
Message: <web.57fff0b4d36b3cadb1933f770@news.povray.org>
Simple test of blob media using potential pattern of version 3.71.
Download 'potential_pattern1test_blob.pov.txt' (4 KB)
Subject: Re: test blob media for potential pattern
Date: 13 Oct 2016 22:10:00
Message: <web.58003db8302fb87eb1933f770@news.povray.org>
Sorry about the double post! Text of scene file was meant for the appropriate
group, not this one.
This file has Sturm=on and is to show bad artifacts, use Sturm=off to render
cleaner.
For version 3.71.
Date: 14 Oct 2016 02:30:01
Message: <web.58007ac8302fb87eb1933f770@news.povray.org>
sorry again, there's another thing I noticed looking at the scene file I have
and had put here.
sturm keyword was left by itself in the first blob statement. Sturm was intended
to also have the #if directive line same as those for the pigment and density
statements.
Please be aware sturm needs to be left out for a cleaner render, otherwise you
will see bad artifacts.
On another note, I am trying a pre-declared instance of the blob statement and
using it as:
object
 Blob
to replace each full statement. You can easily do the same by cutting and
pasting the first blob {...} portion and #declare Blob= blob {...}
This will work like before, no problem here with:
potential {object{Blob}}
