POV-Ray : Newsgroups : povray.binaries.scene-files : Spline must have at least one entry. Server Time
20 Apr 2024 11:59:48 EDT (-0400)
  Spline must have at least one entry. (Message 1 to 5 of 5)
Subject: Spline must have at least one entry.
Date: 27 Jun 2015 10:45:00
Message: <web.558eb6aa8838b9567a3e03fe0@news.povray.org>
I try meshmaker.inc
Problem. Splines aren't closed
But, in konsole:
File "Empty.pov" line 332: Parse Error: Spline must have at least one entry.
Fatal error in parser: Cannot parse input.
Render failed.
Download 'empty.pov.txt' (17 KB)
Subject: Re: Spline must have at least one entry.
Date: 27 Jun 2015 11:26:56
Message: <558ec0c0$1@news.povray.org>
On 27/06/2015 15:43, LanuHum wrote:
> I try meshmaker.inc
> But, in konsole:
> Render failed.
In the file you supplied the splines are missing the closing }
Is that the problem?
Regards
Date: 27 Jun 2015 12:10:01
Message: <web.558ecac5afb778de7a3e03fe0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> Hi,
> Regards
>      Stephen
Hi!
Thank you!
New problem!
At the bottom of a vessel triangles are visible
Download 'meshmaker.jpg' (154 KB)
Preview of image 'meshmaker.jpg'
Date: 27 Jun 2015 19:42:42
Message: <558f34f2@news.povray.org>
>> Hi,
>> Regards
>>       Stephen
> Hi!
> Thank you!
> New problem!
Does the surface have zero thickness or do you have coincident surfaces?
You have sevral messages about normalizing zero-length (null) vectors.
The results are undefined and may explain your artefacts.
Try cutting your object in half, parallel to it's axis, using a textured
plane or box, like pigment{rgb <0,1,0>}. It may reveal some problem.
Date: 27 Jun 2015 21:15:00
Message: <web.558f4a03afb778de7a3e03fe0@news.povray.org>
zero thickness - no
Each end of a curve is on other party of an axis.
But how differently to make a bottom closed?
Download '0004.meshmaker.jpg' (46 KB)
Preview of image '0004.meshmaker.jpg'
