POV-Ray : Newsgroups : povray.binaries.scene-files : Rusty bearing Server Time
26 Mar 2026 16:44:28 EDT (-0400)
  Rusty bearing (Message 1 to 8 of 8)
Subject: Rusty bearing
Date: 8 Feb 2014 02:50:01
Message: <web.52f5e09fa98583267a3e03fe0@news.povray.org>
Download 'rusty_bearing.7z.zip' (483 KB)
Subject: Re: Rusty bearing
Date: 8 Feb 2014 03:57:26
Message: <52f5f176$1@news.povray.org>
Bogus ini file.
Possible Parse Error: Cannot find file
'/home/leonid/blender/povwip/povwip.pov',
 even after trying to append file type extension.
Pov file seems ok
Date: 8 Feb 2014 04:20:01
Message: <web.52f5f649d4e1acd97a3e03fe0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Bogus ini file.
> Pov file seems ok
In the Rusty_bearing.ini file you have to change ways to the.
Input_File_Name ='\bla\bla\bla\Rusty_bearing.pov'
Output_File_Name = '\bla\bla\bla\Rusty_bearing.png'
Date: 8 Feb 2014 14:22:00
Message: <52f683d8$1@news.povray.org>
>> Bogus ini file.
>> Pov file seems ok
Or beter still: Put the files in a folder and remove the path before the
files' names.
Hint: When publishing scenes, remove any paths, especialy any absolute
ones, and put all required files in a single folder.
Subject: Re: Rusty bearing: a collection of rusty metals
Date: 9 Feb 2014 03:34:11
Message: <52f73d83$1@news.povray.org>
I have made a selection of rusty metals that have been offered over the
years in these newsgroups. Names of authors (and sometimes dates) are
given for each of them. You have already Xplo's. This list is certainly
not exhaustive but it is what I have collected.
// Old pitted iron texture
// Created by Kenneth (povray.binaries.images 01-04-2009)
#declare Ke_old_pitted_iron =
   granite  // AGATE works well for this too.
     color_map {
       [0.000 rgb .8*<.4, .4, .380>]
       [0.153 rgb <0.4, 0.4, 0.4>]
       [0.398 rgb .5*<0.7, 0.4, 0.25>]
       [0.398 rgb .2*<0.7, 0.7, 0.7>]
       [1.000 rgb <0.545, 0.380, 0.345>]
   finish {
     ambient 0 // 0.2
     diffuse 1
     phong .6
     phong_size 24
   normal {granite .7 scale 9}
   scale 0.05	//use for scaling to object size (TdG)
// Rusty steel
// Created by Mike Sobers (povray.binaries.images 30-03-2009)
#declare radiosity_on = true;
#declare globalreflection = 1;
#declare base =
   pigment { color rgb <0.91, 0.95, 0.91>*0.5}
   normal {
      wrinkles
       normal_map {
         [ 0.00 granite 0.00 scale 0.001]
         [ 0.20 granite 0.0 ]
         [ 0.28 wrinkles 0.05 turbulence 0.5 scale 0.005]
         [ 0.38 wrinkles 0.05 turbulence 0.5 scale 0.005]
         [ 0.40 granite 0.0 ]
         [ 0.62 granite 0.05 turbulence 0.5 scale 0.005]
         [ 0.90 granite 0.0 ]
         [ 1.00 granite 0.00 scale 0.001]
   turbulence 0.05
   scale 300
   #if (radiosity_on)
     finish {
       ambient 0.0
       brilliance 2
       diffuse 0.3
       metallic
       specular 0.80
       roughness 1/2000
       reflection 0.9*globalreflection
   #else
     finish {
       ambient 0.01
       brilliance 2
       diffuse 0.3
       metallic
       specular 0.80
       roughness 1/2000
#declare tex1 =
     granite
     color_map {
       [ 0 color rgb <0.7, 0.4, 0.2> ]
       [ 1 color rgb <0.6, 0.2, 0.05> ]
     } turbulence 0.2 scale 0.5
   normal {
     bumps 0.2
     turbulence 0.05
     scale 0.5
   #if (radiosity_on)
     finish {
       ambient 0.0
       brilliance 2
       diffuse 0.3
       metallic
       specular 0.20
       roughness 1/20
       reflection 0.1*globalreflection
   #else
     finish {
       ambient 0.01
       brilliance 2
       diffuse 0.3
       metallic
       specular 0.20
       roughness 1/20
#declare tex2 =
   wrinkles
   texture_map {
      [0  base]
      [0.5 tex1 ]
   scale 0.2 turbulence 0.5
#declare MS_RustySteel =
   wrinkles
   texture_map {
      [0.00  base]
      [0.10  base]
      [0.10  tex2 scale 0.005]
      [0.11  tex2 scale 0.005]
      [0.12  base]
      [0.50  base]
      [0.70  tex2 scale 0.05]
// A rusty iron
// Created by Meothuru (povray.binaries.images 29-03-2009)
#declare Me_RustyIron =
     spherical
     turbulence <1, 1, 1>
     omega 1
     lambda 6
     color_map {
       [ 0.1 color rgb <0.478431, 0.513725, 0.462745> ]
   normal {
     boxed
     30
     omega 1
     lambda 6
     frequency 15
   finish {
     ambient rgb <0, 0, 0>
     diffuse 0.3
     specular 0.6
     conserve_energy
     reflection {
       rgb <0.1, 0.1, 0.1>
       metallic 1
   scale 15
// Corroded metal (can also be used for stone with patina)
// Created by Meothuru (povray.text.scene-files 13-11-2007)
// uncomment the lines below to get the metal corrosion. otherwise
'stone' texture
#declare Me_corrodedMetal1 =
//texture {T_Silver_3C}
     cells
     turbulence 1 octaves 5 omega 1 lambda 5
     //pigment_map {
     //  [0	Black filter 0.0]
     //  [1	White filter 0.99]
   normal {
     cells -5
     accuracy 0.001
// and with color variation as given by Grassblade:
#declare Me_corrodedMetal2 =
     cells
     color_map {
       [0.0 color rgb <0.5,0.3,0.1>]
       [0.5 color rgb <0.45, 0.45, 0.45>]
       [1.0 color rgb <0.5,0.3,0.1>]
   normal {
     cells -5
     accuracy 0.001
//or:
#declare Me_corrodedMetal3=
   cells
   texture_map {
     [0.0 Me_corrodedMetal2]
     [0.5 MGrayFro]	//T_Silver_3C]
     [1.0 Me_corrodedMetal2]
// Cast metal Texture
// Created By Tim Attwood
#declare TA_CastMetal =
    pigment{rgb <0.8, 0.8, 0.8>}		//(0.5) change to needs (TdG)
    normal{facets coords 1 scale 1}	//(scale 0.1)
    finish {
       ambient 0
       brilliance 2
       diffuse 0.7		//(0.6) change to needs (TdG)
       metallic
       specular 0.50
       roughness 5/60
       reflection 0.1
    scale 0.35
// Rusty Chrome texture by David Anjo
#declare TM_Rusty_Chrome =
   granite
   color_map {
       [0.00 color rgb<0.400, 0.400, 0.400>]
       [0.70 color rgb<0.498, 0.498, 0.498>]
       [0.70 color rgb<0.898, 0.518, 0.278>]
       [0.75 color rgb<0.698, 0.137, 0.000>]
       [0.80 color rgb<0.698, 0.400, 0.078>]
       [0.80 color rgb<0.698, 0.439, 0.078>]
       [0.85 color rgb<0.498, 0.298, 0.278>]
       [0.85 color rgb<0.498, 0.318, 0.278>]
       [0.90 color rgb<0.878, 0.498, 0.278>]
       [0.90 color rgb<0.498, 0.498, 0.498>]
       [1.00 color rgb<0.400, 0.400, 0.400>]
  finish {
   brilliance 6.0
   phong 0.25    metallic
   reflection 0.05
Date: 9 Feb 2014 04:15:01
Message: <web.52f746a7caa2b3387a3e03fe0@news.povray.org>
> Thomas
Thanks!
Date: 9 Feb 2014 17:30:01
Message: <web.52f800f2caa2b338192ae5f10@news.povray.org>
Thanks, not only for the textures, but for your careful documentation of
sources.
Date: 10 Feb 2014 03:17:56
Message: <52f88b34$1@news.povray.org>
> sources.
You are welcome. I believe giving sources is the natural thing to do.
The code reflects the maker and sometimes it is necessary to go back to
sources, but essentially, the codes are graciously given to us for our
own use and where possible, we should give credit to the authors.
Possibly my old scientific training in monitoring references ;-)
