POV-Ray : Newsgroups : povray.binaries.scene-files : 3dsmax and povray Server Time
22 May 2025 05:59:57 EDT (-0400)
  3dsmax and povray (Message 1 to 2 of 2)
Subject: 3dsmax and povray
Date: 21 Oct 2006 13:45:01
Message: <web.453a5b5178886be78ca7f8dc0@news.povray.org>
Hello I need to post some files here this is related to a thread about
3dsmax and POVRAY:
nemesis said,
"nemesis" <nam### [at] gmailcom> wrote:
> what a waste of space...
> Anyway, einarabelc5, rendering in povray with NVidia hardware won't do you
> any good, AFAIK, since povray rendering happens on the CPU.
> "3D-accelerated" hardware is designed for fast pixel-fill-rates of
> real-time polygonal graphics of 3D games.  They are not designed for the
> kinds of accurate calculations povray and most raytracers require.
> Although there is ongoing work to get raytracer algorithms to be adapted to
> regular 3D-boards...
> today, a povray render with or without Gelato may take about the same
> time...
> and regarding the cartonish looks, i once saw in this thread a render in
> which the guy converted from 3DMax textures to povray and it looked kinda
> dumb as well.  It had something to do with poor job from the converter.  In
> the end, Warp tweaked the textures by hand (he inverted the bumps values on
> the normals or something) and it looked great.
I respond:
 Thanks thats the best I've gotten so far. I've been working with the person
who developes the exporter 3dwin, this Is the results we have gotten:
"einarabelc5,
the rabbit imports well to 3DWin and renders with POV-Ray.
Of course the ase file contains additional objects like bones and
other helper objects. In order to render it properly you need to delete
them or hide/exclude them from export.
In 3ds max most of the objects are subdivided. This is not exported to
ase. So, the rabbit looks a little bit blocky.
All this issues can also be solved within Rheingold3D (hide objects,
subdivide and render with / export to POV-Ray)
Thank you"
You see there are so many other problems between 3dsmax and pov than only
textures...
Just see the original rendered in 3dsmax and what they did with 3dwin and
povray...
This is a scene originally found in 3ds max 8 dvd scenes folder...
Download 'rabbit.zip' (452 KB)
Subject: Re: 3dsmax and povray
Date: 21 Oct 2006 14:14:50
Message: <lsokj2tms9lf7uvukg24uutfesd2om4qgm@4ax.com>
On Sat, 21 Oct 2006 13:39:29 EDT, "einarabelc5" <ein### [at] hotmailcom> wrote:
>I respond:
>"einarabelc5,
Can you export the rabbit as an OBJ file. If you can try converting it with
PoseRay. Or try a 3DS format. I can see why you are complaining.
I did not like the textures 3DWin gave objects, too flat and shiny
Regards
