POV-Ray : Newsgroups : povray.binaries.scene-files : Character Map display Server Time
13 Jan 2026 11:30:31 EST (-0500)
  Character Map display (Message 1 to 3 of 3)
Subject: Character Map display
Date: 4 May 2001 14:46:44
Message: <d8u5ftg93dui5cvrf4bnq43l94n9jp81al@4ax.com>
Hi all,
this is a little file I use to look at what characters a font
contains.
Thought I'd share since it comes in handy to look at a font and figure
out if there's a problem with the character mapping.
You need to adapt the sLabelFont variable for your system.
For a quick preview, you can render at 640x480, but you need to render
this at least at 1024x768 for a good look at the characters.
Enjoy,
- Lutz
//  This file was generated for POV-Ray V3.1 by
//  Moray V3.3 For Windows
default {
    pigment { rgb <1,0.7,0> }
background { color <0.000,0.000,0.000> }
camera {  //  Camera Camera01
  location  <      1.800,      -0.700,       10.00>
  sky       <    0.00000,     0.00000,     1.00000>
  up        <        0.0,         0.0,         1.0>
  right     <    1.49828,         0.0,         0.0>
  angle         99.33909    // Vertical      67.754
  look_at   <      1.80,      -0.5,       0.705>
// *******  L I G H T S *******
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  translate  <2.4, 0.0, 14.3>
// ********  OBJECTS  *******
#declare sFontToMap = "../Users/frozen.ttf"
#declare sLabelFont = "D:/WINNT/Fonts/Arial.ttf"
#declare BaseChar=32;
#declare CountY=0;
#while (CountY < 14)
	#if (  BaseChar+CountY*16<=240)
		text {   // TText017
		  ttf   sLabelFont,
		  str(BaseChar+CountY*16,3,0),
		  0.1,  // Depth
		  <0.0,   0.0, 0.0> // Offset
		  scale 0.8
		  translate  <-7, 6-CountY, 0.0>
		#declare CountX=0;
		#while (CountX < 16)
			text {   // TText017
			  ttf    sFontToMap,
			  chr(BaseChar+CountX+CountY*16),
			  0.1,  // Depth
			  translate  <CountX-5, 6-CountY, 0.0>
			text {   // TText017
			  ttf    sLabelFont,
			  str(BaseChar+CountX+CountY*16,3,0),
			  0.1,  // Depth
			  scale  0.2
			  translate  <CountX-5.2, 5.8-CountY, 0.1>
			  texture { pigment { rgb <1,1,0> } }
			#declare CountX=CountX+1;
  	#declare CountY=CountY+1;
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Re: Character Map display
Date: 4 May 2001 23:45:42
Message: <3af37766$1@news.povray.org>
> Hi all,
> contains.
That's pretty useful. Cheers!
Tek
http://www.evilsuperbrain.com
Date: 5 May 2001 15:00:50
Message: <udi8ftg9tn3eblklii17pouli5epfk5f33@4ax.com>
On Fri, 04 May 2001 20:46:44 +0200, Lutz Kretzschmar <lut### [at] stmuccom> wrote:
>contains.
Hi Lutz,
Just for  info, your program works fine with POVray 3.1, but Megapov 6 & 7 both have
problems.
Some fonts, e.g. Centurion Old, in Megapov results in "Error reading TrueType font
file at
line 1648 ......TRUETYPE.C"
Other fonts just display chars up to index 127 and nothing thereafter.  Seems like a
bug in
Megapov.
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
