POV-Ray : Newsgroups : povray.binaries.scene-files : Harmonagraph Server Time
24 Apr 2024 20:09:42 EDT (-0400)
  Harmonagraph (Message 1 to 1 of 1)
Subject: Harmonagraph
Date: 23 Sep 2016 12:16:25
Message: <b3laubhopa6jq34343aivdrfht9uoec5v9@4ax.com>
This is the scene file for the Harmonagraph
AQ
// Persistence of Vision Ray Tracer Scene Description File
// File: Harmonograph xx.pov
// Vers: 3.7
// Desc: Simulation of a 2 pendulum harmonograph
// Date: September 2016
// Auth: John Cranmer
#version 3.7;
global_settings {
  assumed_gamma 1.0
#declare Single_Col     = rgb <1.0, 0.5, 0.2>;   // single colour pattern
#declare Rainbow        = true;                  // rainbow coloured trace. Single
colours do not work well
#declare Rand_Col       = false;                 // randomised colour map
#declare R              = seed (99);             // seed for random number generation
#declare Radius         = 0.02;                  // radius of the cylinders used to
draw the pattern (0.01 to 0.05)
#declare Number         = 250000;                // Number of points to draw  (100,000
to 250,000 work)
#declare r              = 1.5/Number;
#declare S              = 12;                    // scale factor for drawing
#declare Front_to_Back  = true;                  // draw front to back or back to
front - as cylinders are offset in z makes a considerable difference
#declare xScale         = 1.3;
#declare f1             = 1.25;                   // frequency
#declare f2             = 7.5;
#declare f3             = 8;
#declare f4             = 5;
#declare a1             = 180;                    // initial offset
#declare a2             = 90;
#declare a3             = 0;
#declare a4             = 45;
#declare e              = 2.71828183;
  location < 0, 0,-80>
  look_at  < 0, 0,  0>
  right x * image_width / image_height
  angle 50
light_source {
  -z * 200
  color 1
  shadowless
background { rgb 0.5 }
// Load colour values into the array
#declare Col = array[7][4]
#for (j,0,6,1)
  #for (k,1,3,1)
    #declare Col[j][k] = int(2*rand(R));
// Calculate initial start point
#declare n = 0;
#declare xnew = S * pow(e,-r*n) * (sin(radians(f1 * 2*n + a1)) + sin(radians(f2 * n +
a2)));     // NB THE CHANGE IN THIS LINE
#declare ynew = S * pow(e,-r*n) * (sin(radians(f3 * n + a3)) + sin(radians(f4 * n +
a4)));
#declare n = 1;
#if (Front_to_Back = true)
  #declare FB =  1;
#else
  #declare FB = -1;
#declare Harmonograph = union {
  #while  ( n < Number )
    #declare xold = xnew;
    #declare yold = ynew;
    #declare xnew = S * pow(e,-r*n) * (sin(radians(f1 * 2*n + a1)) + sin(radians((f2 *
n + a2))));       // NB THE CHANGE IN THIS LINE as well
    #declare ynew = S * pow(e,-r*n) * (sin(radians(f3 * n + a3)) + sin(radians((f4 * n
+ a4))));
    cylinder { <xold, yold, FB*n*0.02/Number> <xnew, ynew, FB*n*0.02/Number> Radius
        #if ( Rainbow = true)
          #if (Rand_Col = true)
              function { n / Number }                  // change colour for each
cylinder
              colour_map {
                [0.0/6  rgb < Col[0][1], Col[0][2], Col[0][3] >]
                [1.5/6  rgb < Col[1][1], Col[1][2], Col[1][3] >]
                [2.0/6  rgb < Col[2][1], Col[2][2], Col[2][3] >]
                [3.0/6  rgb < Col[3][1], Col[3][2], Col[3][3] >]
                [4.0/6  rgb < Col[4][1], Col[4][2], Col[4][3] >]
                [5.0/6  rgb < Col[5][1], Col[5][2], Col[5][3] >]
                [6.0/6  rgb < Col[6][1], Col[6][2], Col[6][3] >]
          #else
              colour_map {
                [0.0/6  rgb < 0, 0, 1 >]
                [1.5/6  rgb < 1, 0, 1 >]
                [2.0/6  rgb < 1, 0, 0 >]
                [3.0/6  rgb < 1, 1, 0 >]
                [4.0/6  rgb < 0, 1, 0 >]
                [5.0/6  rgb < 0, 1, 1 >]
                [6.0/6  rgb < 0, 0, 1 >]
        #else
          pigment { Single_Col }
    #declare n = n + 1;
// Draw the pattern
object { Harmonograph
  scale x * xScale
  translate x * 0
  rotate z * 0
